IBM ServeRAID M1015 Stor. Cont. Serial ATA-300/SAS 2.0 600Mbps
Quicklinx: 7RJ0WS00 Mfr#: 90Y4556
Marketing description is not available.
  • Enhanced compatibility
    Designed to integrate seamlessly with PC systems, the Lenovo ServeRAID M1015 storage controller ensures a smooth and reliable connection for managing disk arrays.
  • High-speed performance
    With a data transfer rate of 6 Gbit/s and support for SATA 3 Gb/s / SAS 6 Gb/s interfaces, this storage controller offers rapid data access and transfer speeds, enhancing overall system efficiency.
  • Flexible RAID support
    The Lenovo ServeRAID M1015 provides versatile RAID configuration options, including RAID 0, RAID 1, and RAID 10, allowing for optimized data protection and performance according to your needs.
  • Compact and efficient design
    Its half-length, low-profile form factor makes it an ideal choice for systems with limited space, ensuring a perfect fit without compromising performance.
  • Robust processor technology
    Powered by the LSI LSISAS2008 processor, this storage controller delivers reliable and high-performance management of connected storage devices.
Lenovo ServeRAID M1015 - storage controller - SATA 3Gb/s / SAS 6Gb/s - PCIe 2.0 x8
Storage controller - plug-in card - low profile
Bus Type
PCIe 2.0 x8
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10
Red Hat Enterprise Linux 4, SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Server 10, Microsoft Windows 2003, Red Hat Enterprise Linux 5
1.4 cm x 16.8 cm x 6.9 cm
95 g
3-year warranty
P/N: 7376K5G, 7379KEG, 7379KFG, 7379KGG, 7379KHG, 7379KKG, 7944KAG, 7944KBG, 7945KDG, 7945KEG
Host Bus
PCIe 2.0 x8
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
8
RAID Level
LSI LSISAS2008
2 x SATA 3Gb/s / SAS 6Gb/s - 36 pin 4i Mini MultiLane (internal)
Compatible Slots
1 x PCI Express 2.0 x8 - half-length, low-profile
Limited warranty - 3 years
1.4 cm
16.8 cm
6.9 cm
95 g
10 °C
32 °C
20 - 80% (non-condensing)
