Hypertec - DDR3 - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for HP 280 G1 (micro tower), 6300 Pro, 6305 Pro, Elite 8300 (CMT, MT, SFF)
- Hypertec Legacy - DDR3 - module - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- HP B4U35AA
- Limited lifetime warranty
- Designed For
- HP 280 G1, 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
- Capacity
- 2 GB
- Upgrade Type
- System specific
- HP B4U35AA
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HP 280 G1 , HP Compaq 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
