- Hypertec Legacy - DDR3 - module - 16 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1066 MHz (PC3-8500)
- Quad rank, registered
- OEM Manufacturer Equivalent Part Number
- HP 500666-B21
- Limited lifetime warranty
- Designed For
- HPE ProLiant BL280c G6, BL2x220c G6, BL2x220c G7, BL460c G7, BL490c G7, BL620C G7, BL680c G7, DL160 G6, DL160se G6, DL165 G7, DL180 G6, DL320 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G7, DL580 G7, DL980 G7, ML330 G6, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6
- Capacity
- 16 GB
- Upgrade Type
- System specific
- HP 500666-B21
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HPE ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL2x220c G7, BL460c G6, BL460c G7, BL490c G6, BL490c G7, BL620C G7, BL680c G7, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G7, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 Performance, DL380 G6 Special Rack Server, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL980 G7, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6 Workstation
