The HP RDX Removable Disk Backup System delivers an easy-to-use, affordable and rugged data protection solution for workstations and servers. Backups are simple and pain-free with drag and drop file access. Protect your entire system with the "hands-free" HP RDX Continuous Data Protection Software. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station that does not require a costly upgrade for future, higher capacity cartridges. Portable, durable and rugged removable disk cartridges simply and securely store your backups off site for complete data protection and peace of mind.
Combines the best of tape and disk
The HPE RDX Removable Disk Backup System is based on removable disk technology that handles and operates like a traditional tape drive and media, yet has all of the advantages of disk-to-disk backup. The HPE RDX Removable Disk Backup System allows backups to be accomplished with "hands free" HPE RDX Continuous Data Protection Software, standard ISV backup applications or data can be dragged and dropped directly to the rugged removable storage media. To the host computer, the HPE RDX Removable Disk Cartridge appears as a Windows drive letter with the high performance benefits of a disk based backup system. -
Easy to implement and use
Many small business customers have limited time, knowledge, experience or desire to dedicate to backup and therefore currently have no or very rudimentary backup processes in place. The HPE RDX Removable Disk Backup System offers these customers a complete backup solution that is simple to implement and easy to use. -
Fast backup and restore
Staff productivity and thus customer service can be negatively impacted by the lengthening backup window and restore/recovery times associated with optical backup solutions. The HPE RDX Removable Disk Backup System provides a backup solution that backs up and retrieves data quickly and reliably thus optimizing application availability and staff productivity. -
Affordable cost of ownership
Many small business customers have limited IT budget available for data protection with business owners wanting to reduce IT capital and operational expenditure and protect IT investments to optimize business profitability. The HPE RDX Removable Disk Backup System provides a complete backup solution that has low initial acquisition costs and low on-going media and upgrade costs. -
Removability and portability
To ensure complete data protection against all types of data loss - including on-site system/site destruction or natural disaster - small businesses need the ability to remove their backup and archive data off-site. The HPE RDX Removable Disk Backup System provides a backup solution that enables onsite backup data to be removed, stored and rotated off-site in an easy, safe and secure way. -
Reliability
The HPE RDX Removable Disk Backup System provides a docking station specified for more than 10,000 load and unloads and an HPE RDX cartridge specified for over 5,000 load and unloads and long life expectancy. -
Easy scalability and expandability
Many growing small businesses are experiencing storage capacity growth that is outstripping the capacity/performance of current optical backup solutions. The HPE RDX Removable Disk Backup System provides a backup solution that scales easily as capacity needs grow. Adding capacity is a simple matter of adding cartridges to an existing HPE RDX Removable Disk Backup System USB docking station. The HPE RDX Removable Disk Backup System docking Station will work with all current as well future higher capacity cartridges as they are introduced.
- HPE RDX Removable Disk Backup System - RDX drive - USB 2.0 - internal - with 320 GB Cartridge
- RDX drive - internal
- Interface
- USB 2.0
- 14.68 cm x 17.07 cm x 4.14 cm
- 635 g
- Storage Removable
- RDX cartridge - 5.25" x 1/2H
- Media Type
- RDX cartridge
- Data Transfer Rate
- 30 MBps (external) / 480 MBps (internal)
- Bundled with
- 320 GB Cartridge
- Designed For
- Workstation xw4300, xw4400, xw4550, xw4600, xw6400, xw6600, xw8400, xw8600, xw9400; ProLiant DL120 G7, DL165 G7, DL370 G6, MicroServer, ML110 G3p, ML110 G4, ML110 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G5, ML150 G6, ML310 G3, ML310 G4, ML310 G5, ML330 G6, ML350 G5, ML350 G6, ML370 G5, ML570 G4
- Interface
- USB 2.0
- 14.68 cm
- 17.07 cm
- 4.14 cm
- 635 g
- Bundled with
- 320 GB Cartridge
Storage Removable
- Media Type
- RDX cartridge
- Average Seek / Access Time
- 15 ms
- 1 x USB 2.0 - 4 pin USB Type B
- Compatible Bay
- 1 x 5.25" x 1/2H - front accessible
- Media Included Qty
- 1
- Cables Included
- 1 x USB cable
- MTBF
- 550,000 hours
- VCCI, C-Tick, EN 60950, IEC 60950, UL 60950, CISPR 22, FCC
- 6.6 watt
- Software Included
- Drivers & Utilities, HP RDX Continuous Data Protection Software
- 5 °C
- 45 °C
- 20 - 80% (non-condensing)
- Designed For
- HP Workstation xw4100, xw4200, xw4300, xw4400, xw4550, xw4600, xw6000, xw6200, xw6400, xw6600, xw8000, xw8200, xw8400, xw8600, xw9300, xw9400 , HPE ProLiant DL120 G7, DL165 G7 Base, DL370 G6 Base, DL370 G6 High Performance, MicroServer, ML110 G3, ML110 G3p, ML110 G4, ML110 G5, ML110 G6, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML115 G5, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G2, ML310 G3, ML310 G4, ML310 G5, ML330 G6, ML350 G4, ML350 G4p, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G4, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, ML570 G4, ML570 G4 High Performance
