HPE Proliant ML150 G6 Xeon E5520
Quicklinx: 6M2WWS00 Mfr#: 466133-031
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-ROM
The HP ProLiant ML150 G6 is an entry, dual-processor server that is optimized for price performance. The server ships with improved HP ProLiant Easy Set-up CD for better deployment as well as Insight Management Agents for SIM manageability. The availability of high efficiency redundant power supply and redundant fan options provide additional protection on power and thermal to keep your business running. Data security is ensured by the TPM offering that provides data encryption. Companies with remote locations can take advantage of the now integrated Lights-Out 100 remote management capability to decrease server/company downtime and increase overall productivity. Overall, the HP ProLiant ML150 G6 is easy on your IT budget with significant headroom to grow with your business.
  • Faster Computing Power
    4 core Xeon processors at 1066MHz with 8M L3 cache.Ultimate processor performance with eight total cores.Large cache size processes more transactions.1066MHz maximum front-side bus speed generates faster data flow.
  • Essential Performance and Expandability
    Up to 8x SAS/SATA hot plug storage devices.Easy to deploy additional disk drives for business growth.SAS provides reliable performance with simplified cabling.SATA HDDs provide high capacity at lower total cost of ownership.Optional high efficiency 750W Redundant Power Supply offers more protection to keep your business running.
  • Convertibility and Connectivity
    Rack Mount Enabling Kit.High flexibility for future consolidation.Less trouble with moving or relocation.Ease of use of connecting to existing rack-mount server.
  • Remote Manageability
    Easy to use remote access.Reduces IT expense for repair and maintenance (lower cost computing).Easy to consolidate to other HPE ProLiant products.
HPE ProLiant ML150 G6 Performance - tower - Xeon E5520 2.26 GHz - 4 GB - no HDD
Server - tower - system password, power-on password
Height (Rack Units)
5U
Region: United Kingdom
Server Scalability
2-way
1 x Intel Xeon E5520 / 2.26 GHz (2.53 GHz) (Quad-Core)
Processor Main Features
Hyper-Threading Technology
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB (2 x 4MB (4MB per core pair))
RAM
4 GB (installed) / 24 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
RAID (SATA 1.5Gb/s / SAS) - PCIe (Smart Array P410)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD
Video Memory
32 MB
GigE
Software Included
Drivers & Utilities
42.7 cm x 61.3 cm x 20 cm
24 kg
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 5U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Intel Xeon E5520
Clock Speed
2.26 GHz
Max Turbo Speed
2.53 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel 5500
Front Side Bus
1066 MHz
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
RAM
Installed Size
4 GB / 24 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1066 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
12 (Total) / 10 (empty)
Unbuffered
Configuration Features
2 x 2 GB
RAM Supported
PC3-10600 - 24 GB unbuffered , PC3-10600 - 48 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe
Controller Interface Type
SATA 1.5Gb/s / SAS
Storage Controller Name
Smart Array P410
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
256 MB
Optical Storage
DVD-ROM DVD - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Memory
32 MB
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express
Ethernet Controller
HP NC107i
Wake on LAN (WoL), PXE support
Bays
3 (total) / 2 (free) x external 5.25" x 1/2H , 4 (total) / 4 (free) x hot-swap 3.5" x 1/3H
Slots
2 (total) / 1 (free) x CPU , 12 (total) / 10 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCI , 1 (total) / 1 (free) x PCIe x8 (x4 mode) , 2 (total) / 2 (free) x PCIe 2.0 x8 (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x16 (x16 mode)
6 x USB 2.0 (2 front, 4 rear) , 1 x serial , 1 x PS/2 mouse , 1 x VGA , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x management
System password, power-on password
ACPI 2.0
Power supply
Installed Qty
1
Power Provided
460 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
Software
Drivers & Utilities
42.7 cm
61.3 cm
20 cm
24 kg
10 °C
35 °C
10 - 90%
