HPE StorageWorks 81Q PCI-e FC HBA
Quicklinx: 7ZYYWS00 Mfr#: AK344A
HP StorageWorks 81Q PCI-e Fibre Channel Host Bus Adapter brings datacenter infrastructure components to a higher level of performance and efficiency. The HP StorageWorks 81Q PCI-e FC Host Bus Adapter is priced only slightly higher than an equivalent 4Gb HBA, yet, it has the ability to deliver twice the I/O performance. In addition, an 8Gb FC HBA purchased today will protect your investment longer than if you were to purchase an equivalent 4Gb HBA. If you are using storage intensive applications, such as rich media, the increased performance of the 8Gb infrastructure allows you to store and retrieve critical information faster.
The virtualization of servers has become an important capability for most datacenters. The ability to improve overall server utilization, resulting in significant cost savings, has made server virtualization a "must-have" for most enterprises. By having an HBA that supports and maximizes your server virtualization efforts, you are protecting your significant investments in virtualization technology.
Since most of today's datacenters are required to be available 24 X 7, it is critical that infrastructure components have failover capabilities. By installing redundant HBAs into your servers, you can feel confident that your servers will remain connected to mission-critical stored data.
Finally, today's enterprises are becoming more and more sensitive to the power consumption within the datacenter. The 81Q PCI-e FC Host Bus Adapter provides a number of features that work together to reduce power consumption, thus delivering a "green" benefit within the server.
HPE StorageWorks 81Q - host bus adapter
Host bus adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports
Fibre Channel
16.8 cm x 6.4 cm
8Gb Fibre Channel
Linux, Microsoft Windows Server 2003, Red Hat Enterprise Linux 5 for Intel x86 / AMD64 / EM64T, Red Hat Enterprise Linux 5.1 for Intel x86 / AMD64 / EM64T, SuSE Linux Enterprise Server 10 SP1
Pricing Type
Remarketed
ProLiant DL120 G6, DL160 G5p, DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL170h G6, DL180 G6, DL2x170h G6, DL320 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL4x170h G6, DL580 G7, DL585 G6, DL585 G7, DL785 G6, ML330 G6, ML350 G6, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6
Host bus adapter
Plug-in card
PCI Express
Ports
Fibre Channel
Wired
8Gb Fibre Channel
1 x Fibre Channel - LC - x 2
Compatible Slots
1 x PCI Express
Low-profile bracket
Pricing Type
Remarketed
16.8 cm
6.4 cm
55 °C
10 - 90%
HPE ProLiant DL120 G5, DL120 G6, DL120 G6 Base, DL120 G6 Entry, DL120 G6 Performance, DL160 G5 Special Server, DL160 G5p, DL160 G5p Special Server, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G5, DL165 G5 Special Server, DL165 G5p, DL165 G5p Base, DL165 G5p Efficiency, DL165 G5p Entry, DL165 G5p Performance, DL165 G6, DL165 G7, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G6, DL180 G6 Special Server, DL185 G5 Special Server, DL2x170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G5 High Efficiency, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL365 G5, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G5 High Availability Storage Server, DL380 G5 High Efficiency, DL380 G5 Storage Server 2.7TB SAS Model, DL380 G5 Storage Server 6TB SATA Model, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p, DL385 G5p Base, DL385 G5p Entry, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL4x170h G6, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G5, DL585 G5 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6
