Brand
HPE Premier Flex LC/LC OM4 2F Fibre Optic Cable
Quicklinx: BQDLWS00 Mfr#: QK735A
Length: 15m
£202.62 ex VAT
£243.14 inc VAT
Provide more robust and reliable data transfer, due to their lower sensitivity to sharp bends, which can reduce downtime and operating expense.
Fiber optic cable routing can result in 90° bends, cables caught in cabinet doors and kinks. Data loss and transmission errors resulting from these common problems are difficult to troubleshoot, expensive, and increase downtime. HP PremierFlex bendable fiber optic cables solve these problems by providing up to 10 times better bend performance than existing fiber cables.
HP's PremierFlex cables use a bendable fiber technology that significantly improves bend performance over existing fiber cables. This, combined with improvements in fiber clarity and bandwidth, allows HP PremierFlex cables to transmit data over longer distances, at higher rates, with fewer transmission errors.
HPE PremierFlex - network cable - 15 m
Network cable - OM4
Fibre optic
Type of Fibre Optics
Multimode
Length
15 m
Connector
2 x LC multi-mode - male
Connector (Second End)
Brocade 16Gb/12, 16Gb/16, 16Gb/24, 16Gb/28; HPE 1810, 3600, 5500, 8/24, 8/8, SN6000; Modular Smart Array 1040, 2040, 2040 10; StoreFabric SN3600, SN4000, SN6500, SN6600B 32, SN6610, SN6620C 24, SN6650, SN8000B 4-Slot, SN8000B 8-Slot, SN8600B 4-slot; HPE Aruba 2920, 2930F 24, 2930F 48, 2930M 24, 5406
Network Cable Type
Network cable - OM4
Fibre optic
Multimode
Fibre Qty
2
Length
15 m
Connector
Brocade 16Gb/12 SAN Switch Module for HPE Synergy, 16Gb/16 SAN Switch for HP BladeSystem c-Class, 16Gb/24 Fibre Channel SAN Switch Module for HPE Synergy, 16Gb/24 SAN Switch Module Power Pack+ for HPE Synergy, 16Gb/28 SAN Switch for HP BladeSystem c-Class, 16Gb/28 SAN Switch Power Pack+ for BladeSystem c-Class , HP 3100-8-PoE v2 EI Switch , HPE 1606 Power Pack+ Extension SAN Switch, 1810-8G v2 Switch, 3600-24 v2 EI, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP v2 EI, 3600-48-PoE+ v2 SI, 5500-24G-SFP HI Switch with 2 Interface Slots, 8/24 Base (16) Full Fabric Ports Enabled SAN, 8/8 Base (0) e-port SAN, MSL4048 Ultrium 1760, SAN Switch 8/80 Power Pack+, SN6000B, SN8000B 32-port 8Gb/s Director Blade , HPE Modular Smart Array 1040 Dual Controller LFF Storage, 1040 Dual Controller SFF Bundle, 1040 Dual Controller SFF Storage, 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAS Dual Controller LFF Storage, 2040 SAS Dual Controller SFF Bundle , HPE StoreFabric 8/24 8Gb Bundled Fibre Channel Switch, SN3600B, SN3600B Power Pack+, SN4000B Power Pack+ SAN Extension Switch, SN6500B 16Gb 96-port/48-port Active Fibre Channel Switch, SN6500B 16Gb 96-port/48-port Active Power Pack+ Fibre Channel Switch, SN6500B Power Pack+, SN6600B 32Gb 48/24, SN6600B 32Gb 48/24 Power Pack+, SN6600B 32Gb 48/48, SN6600B 32Gb 48/48 Power Pack+ Fibre Channel Switch, SN6610C, SN6620C 24-port 32Gb SFP+ Fibre Channel Switch, SN6650B, SN6650B Power PAck, SN8000B 4-Slot Power Pack+ SAN Director Switch, SN8000B 8-Slot Power Pack+ SAN Backbone Director Switch, SN8600B 4-slot Power Pack+ Director Switch , HPE Aruba 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 2930M 24 Smart Rate POE+ 1-Slot, 5406 zl
Length: 15m
Brand: HPE
Stock Status: In stock
