- HPE network cable - 1 m
- Network cable - OM3
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Cable Length
- 1 m
- Length
- 1 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Designed For
- Brocade 16Gb/12, 16Gb/24; HPE 3600, 8/24, 8/8, SN3600B 32, SN6000, SN6610C 32, SN6710C 64, SN6720C 64, SN6750, SN8500C/SN8700C 48, SN8700C 64; SimpliVity 380 Gen10, 380 Gen9; StoreFabric SN3600, SN6500, SN6600B 32, SN6610, SN6620C 24, SN6650, SN8600B 4-slot; HPE Aruba 2530, 2920, 2930F 24, 5406
- Network Cable Type
- Technology
- Fibre optic
- Multimode
- 50 / 125 micron
- Cable Length
- 1 m
- Length
- 1 m
- Connector
- Designed For
- Brocade 16Gb/12 SAN Switch Module for HPE Synergy, 16Gb/24 Fibre Channel SAN Switch Module for HPE Synergy, 16Gb/24 SAN Switch Module Power Pack+ for HPE Synergy , HPE 3600-24 v2 EI, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP v2 EI, 3600-48-PoE+ v2 SI, 8/24 Base (16) Full Fabric Ports Enabled SAN, 8/8 Base (0) e-port SAN, SN3600B 32Gb 24/8 8-port 16Gb Short Wave SFP+ Fibre Channel Switch, SN6000B, SN6610C 32Gb 32/24 32Gb Short Wave SFP+ Fibre Channel Switch, SN6610C 32Gb 32/24 32Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6710C 64Gb 24/8 32Gb Short Wave SFP+ Fibre Channel Switch, SN6710C 64Gb 24/8 32Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6710C 64Gb 24/8 64Gb Short Wave SFP+ Fibre Channel Switch, SN6710C 64Gb 24/8 64Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6710C 64Gb 24/8 Fibre Channel Switch, SN6720C 64Gb 48/24 32Gb Short Wave SFP+ Fibre Channel Switch, SN6720C 64Gb 48/24 32Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6720C 64Gb 48/24 64Gb Short Wave SFP+ Fibre Channel Switch, SN6720C 64Gb 48/24 64Gb Short Wave SFP+ Fibre Channel v2 Switch, SN6720C 64Gb 48/24 Fibre Channel Switch, SN6750B, SN6750B Port Side Intake, SN8500C/SN8700C 48-port 32Gb Fibre Channel Director Module, SN8700C 64Gb 48-port 32Gb SFP+ Fibre Channel Director Module, SN8700C 64Gb 48-port Fibre Channel Director Module , HPE SimpliVity 380 Gen10 Node, 380 Gen9 Node , HPE StoreFabric SN3600B, SN3600B Power Pack+, SN6500B Power Pack+, SN6600B 32Gb 48/24, SN6600B 32Gb 48/24 Power Pack+, SN6600B 32Gb 48/48, SN6600B 32Gb 48/48 Power Pack+ Fibre Channel Switch, SN6610C, SN6620C 24-port 32Gb SFP+ Fibre Channel Switch, SN6650B, SN6650B Power PAck, SN8600B 4-slot Power Pack+ Director Switch , HPE Aruba 2530-48-PoE+, 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 5406 zl
