1405 series switch is Plug-and-Play unmanaged fixed-port layer 2 switches designed for small offices. The switch is preconfigured for fast, easy installation, with connections using low-cost Ethernet copper cabling. It supports administration-friendly features such as auto-negotiation and automatic cable type detection (MDI/MDIX). It is fan less for quiet and "green" operation, and designed for high reliability, long life, low power consumption, and low total cost of ownership.
Traffic prioritization
Allows real-time traffic classification mapped to multiple hardware queues. -
Class of Service (CoS)
Prioritizes traffic by honoring Differentiated Services Code Point (DSCP). -
Auto-MDIX
Automatically adjusts for straight-through or crossover cables on all 10/100 and 10/100/1000 ports. -
Flow control
Helps ensure reliable communications during full-duplex operation. -
Comprehensive LED display with per-port indicators
Provides an at-a-glance view of status, activity, speed, and full-duplex operation. -
Fanless design
Enables quiet operation for deployment in open spaces.
- HPE OfficeConnect 1405 5G v3 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Switching capacity: 10 Gbps , Throughput: 7.4 Mpps , Latency (100 Mbps): 3 µs , Latency (1000Base-T): 2.6 µs
- MAC Address Table Size
- 2048 entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, full duplex capability, Layer 2 switching, auto-uplink (auto MDI/MDI-X), half duplex mode, Quality of Service (QoS), fanless, Energy Efficient Ethernet, 1MB packet buffer, Class of Service (CoS), DiffServ Code Point (DSCP) support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 11.43 cm x 9.14 cm x 3.56 cm
- 180 g
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- 2048 entries
- 9216 bytes
- 5 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 3 Watt
- Plug and Play, UL 60950, EN55022 Class B, ICES-003 Class B, RoHS, IEC 60950-1, EN 60950-1, WEEE, CAN/CSA C22.2 No. 60950-1-03, AS/NZS CISPR 22 Class B, FCC Part 15 Class B
- 11.43 cm
- 9.14 cm
- 3.56 cm
- 180 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 15 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
