HPE HP X120 SFP (mini-GBIC) Transceiver Module
Quicklinx: 7S82WS00 Mfr#: jd118b
Type: Modules
£178.61 ex VAT
£214.33 inc VAT
Intel Xeon DL360 G4p (3.6GHz/Single-core/2MB/110W) Full Processor Option Kit
Solve your mission-critical IT challenges of managing and keeping secure the capabilities and data crucial to your business with a powerful and reliable Intel Xeon processor server. These top-of-the-line processors deliver performance that is ideal for your most data-demanding workloads with improved scalability and increased memory and I/O capacity allowing you to handily adapt to changes in short-term business demands and address requirements for longer-term business growth. These advanced reliability and security features work to maintain data integrity accelerate encrypted transactions and maximize the availability of mission-critical applications. The powerful and reliable Intel Xeon processor servers provide flexibility for your business critical solutions.
HPE X120 - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
1GbE
HP 3100, A5120, E4500; HPE 10512, 12504, 1910, 3100, 3600, 3610, 4200, 4500, 5120, 5500, 5810, 5820AF, 5830AF, 5920AF, 7506, WX5002, WX5004; FlexFabric 1.92, 11908, 12902; FlexNetwork MSR3048
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-SX - LC
Compatible Slots
1 x SFP (mini-GBIC)
HP 3100-8-PoE v2 EI Switch, A5120-24G-PoE+ SI Switch, A5120-48G SI Switch, E4500-24-PoE , HPE 10512 Switch Chassis, 12504 AC Switch Chassis, 1910-16G Switch, 1910-24G Switch, 1910-24G-PoE (170 W) Switch, 1910-24G-PoE (365 W) Switch, 1910-48G Switch, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 3100-16 DC EI Switch, 3100-16 EI Switch, 3100-16-PoE EI Switch, 3100-24 DC EI Switch, 3100-24 EI Switch, 3100-24 V2 EI Switch, 3100-24-PoE EI Switch, 3100-24-PoE v2 EI Switch, 3100-48 Switch, 3100-8 DC EI Switch, 3100-8 EI Switch, 3100-8 v2 SI Switch, 3100-8-PoE EI Switch, 3600-24 EI Switch, 3600-24 SI Switch, 3600-24 v2 EI, 3600-24-PoE EI Switch, 3600-24-PoE SI Switch, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP EI Switch, 3600-24-SFP v2 EI, 3600-24TP SI Switch, 3600-48 EI Switch, 3600-48 SI Switch, 3600-48-PoE EI Switch, 3600-48-PoE SI Switch, 3600-48-PoE+ v2 SI, 3610-24 Switch, 3610-24-SFP Switch, 3610-24-TP Switch, 3610-48 Switch, 4200-12G Switch, 4500-24 Switch, 4500-24-PoE Switch, 4500-48 Switch, 4500-48-PoE Switch, 5120-16G SI, 5120-24G SI, 5120-24G-PoE+ SI, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5810-48G Switch, 5820AF-24XG, 5830AF-48G Switch with 1 Interface Slot, 5830AF-96G Switch, 5920AF-24XG Switch, 7506, WX5002 Access Controller, WX5004 Access Controller , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis , HPE FlexNetwork MSR3048
7S82 C2G 2m SC-SC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £15.04
Type: Modules
Brand: HPE
