The HP Virtual Connect 8Gb 20-port Fibre Channel Module for c-Class BladeSystem offers enhanced virtual connect capabilities, allowing up to 128 virtual machines running on the same physical server to access separate storage resources. Provisioned storage resource is associated directly to a specific virtual machine-even if the virtual server is re-allocated within the BladeSystem. Storage management of virtual machines is no longer limited by single, physical HBA on a server blade. SAN administrators can now manage virtual HBAs with the same methods and viewpoint of physical HBAs. Virtual Connect 8Gb 20-port Fibre Channel Module is the simplest, most flexible connection to your SAN fabrics. The HP Virtual Connect 8Gb 20-port Fibre Channel Module unravels server connections by cleanly separating the server enclosure from SAN, makes SAN fabrics easier to layout by reducing cables without adding switches to the domain, and allows you to change servers in just minutes, not days.
Ease of Operations and Deployment
HP Virtual Connect 8Gb 20-port Fibre Channel Module for c-Class BladeSystem is compatible with all NPIV capable switches and requires minimal management to deploy.HP Virtual Connect 8Gb 20-port Fibre Channel Module for c-Class BladeSystem appears as a pass-through device to the network and removes all interoperability concerns and complicated switch management.
- HPE Virtual Connect 8Gb 20-Port Fibre Channel Module - switch - 20 ports - plug-in module
- Switch - 20 ports
- Enclosure Type
- Plug-in module
- Subtype
- Fibre Channel
- Ports
- 20 x 8Gb Fibre Channel
- Auto-negotiation, manageable
- 26.8 cm x 9.3 cm x 2.8 cm
- 1.27 kg
- 1-year warranty
- Designed For
- BLc3000 Enclosure; BLc3000 Single-Phase Enclosure; BLc7000 Enclosure; BLc7000 Enclosure Model X; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant c3000
- Switch - 20 ports
- Enclosure Type
- Plug-in module
- Subtype
- Fibre Channel
- Compatible Slots
- 1 x Expansion Slot
- Ports
- Fibre Channel
- FC-AL, FC-AL-2, FC-FG, FC-FLA, FC-GS, FC-GS-2, FC-GS-3, FC-PH, FC-PH-2, FC-PH-3, FC-VI
- Status Indicators
- Port status, link OK, module locator, link/activity
- 16 x 8Gb Fibre Channel - backplane , 4 x SFP+
- 36 Watt
- TUV, VCCI, cUL, EN55022 Class A, AS/NZ 3548 Class A, UL 60950-1, EN 60950-1, WEEE, FCC Part 15 A, MIC Class A
- 26.8 cm
- 9.3 cm
- 2.8 cm
- 1.27 kg
- Limited warranty - parts and labour - 1 year - on-site
- 10 °C
- 35 °C
- 10 - 90%
- Designed For
- HPE BLc3000 Enclosure , HPE BLc3000 Single-Phase Enclosure , HPE BLc7000 Enclosure , HPE BLc7000 Enclosure Model X , HPE BLc7000 Single-Phase Enclosure , HPE BLc7000 Three-Phase Enclosure , HPE ProLiant c3000
