- HPE - power supply - hot-plug / redundant - 1000 Watt - 1217 VA
- Power supply - hot-plug / redundant - plug-in module
- 1.8 kg
- Input Voltage
- AC 100/120/208/220/230/240 V
- Power Capacity
- 1000 Watt / 1217 VA
- 19.6 cm x 42.4 cm x 18.6 cm
- Designed For
- ProLiant DL380 G5, DL385 G5, DL385 G5p
- Input Voltage
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Max Electric Current
- 30 A
- Power Capacity
- Efficiency
- 81.5% (100VAC), 82% (120VAC), 84% (208VAC), 84% (220VAC), 85% (230VAC), 85.5% (240VAC)
- Power Factor (PF)
- 0.98
- 19.6 cm
- 42.4 cm
- 18.6 cm
- 1.8 kg
- Designed For
- HPE ProLiant DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Availability Storage Server, DL380 G5 High Efficiency, DL380 G5 High Performance, DL380 G5 Performance, DL385 G5, DL385 G5 Base, DL385 G5 Carrier-Grade, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p, DL385 G5p Base, DL385 G5p Entry, DL385 G5p High Performance
