HPE 8GB 2Rx8 PC4-2133P-E-15 Standard Kit
Quicklinx: BZQ4WS00 Mfr#: 805669-B21
Do you need to increase the main memory in your HPE entry-level ProLiant Gen9 Servers? The HPE Standard Memory options are designed for the HPE entry-level servers delivering an excellent combination of pricing, quality, reliability, performance and compatibility compared to third-party alternatives.
  • High Performance
    HPE DDR4 Standard Memory performs at industry-standard speeds.HPE DDR4 Standard Memory has built-in intelligence (advanced error detection) to improve performance, reduce downtime and lower energy costs.
  • High Reliability
    HPE DDR4 Standard Memory provides excellent quality and support for HPE ML Gen9 and DL Gen9 10/100 servers.Quality and reliability is engineered into every HPE DDR4 Standard Memory product.
  • Increased Efficiency
    HPE DDR4 Standard Memory is an affordable solution for small and medium business and remote and branch office customers.HPE DDR4 2400 MT/s Standard Memory modules reduce power consumption by up to 20% in comparison to DDR4 2133 MT/s memory modules.
HPE - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Dual rank, unbuffered
Voltage
1.2 V
HP 805669-B21
ProLiant DL20 Gen9, DL20 Gen9 Base, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Special Server, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML30 Gen9, ML30 Gen9 Base, ML30 Gen9 Performance
8 GB
Upgrade Type
System specific
HP 805669-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-15-15)
ECC
Chips Organization
X8
Voltage
1.2 V
Colour Category
Green
HPE ProLiant DL20 Gen9, DL20 Gen9 Base, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Special Server, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML30 Gen9, ML30 Gen9 Base, ML30 Gen9 Performance
