HPE HP DL360 G7, Dual Processor Capable, 1 x Xeon E5606 (2.13Ghz)
Quicklinx: 7GZ0WS00 Mfr#: 470065-505
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
Combining concentrated 1U compute power, HP Insight Control, and essential fault tolerance, the HP ProLiant DL360 G7 is optimized for space constrained installations. Latest Intel Xeon 5600 Series Processors (6 and 4 core), with choice of DDR3 Registered or Unbuffered DIMMs, integrated Smart Array with support up to eight SAS/SATA/SSD drives and dual PCI Express Gen2 technology provide a high performance system, ideal for the full range of scale out applications.
  • More Performance, Capacity and Efficiency in Less Space
    With the addition of two Intel Xeon Processors X5687, X5690 via CTO, the DL360 G7 offers a new level of high performance, power efficiency, and adaptability with Intel QuickPath, Integrated Memory Controller, Turbo Boost, Intelligent Power Technologies and Trusted Execution Technology.Up to 384 GB Registered Memory DIMMS (up to 48 GB Unbuffered). Memory intensive applications benefit from memory buffers, faster memory speeds, 4:1 memory interleaving, online spares and larger memory capacity.The DL360 G7 continues to provide the best in efficiency with Data Center Smart Grid Technologies like the Sea of Sensors, Dynamic Power Capping and High Efficiency/Right-Sized power supplies.More performance/efficiency in the 1U space and more performance in the constrained environment.
  • Smart, Flexible Systems Ready for Complex, Dynamic Environments
    Insight Control - essential infrastructure management that speeds server deployment, proactively manages health, optimizes power management, and offers control from anywhere – available standard on Performance models.iLO 3 allows powerful, hardware-based remote administration and control from a standard web browser to conserve valuable IT staff resources.Server configuration and deployment is simplified with tools like SmartStart, Rapid Deployment Pack, PXE, and ROM-Based Setup Utility (RBSU).Options for integrated VMware, MS HyperV or Citrix XenServer virtualization technologies, through internal USB and SD slot.System Insight Display: A rugged slide-out system diagnostics display saves administrators time with easy to find trouble shooting information at the front of the server.
  • Energy Efficiency Leadership
    HPE unique Data Center Smart Grid Technologies provide intelligent automatic power and cooling with "Sea of Sensors" that manage and adjust power and cooling throughout the server to provide continuous peak performance and efficient cooling throughout the data center.Right-sized HPE ProLiant power supplies deliver 460 Watts at 92% or 94% efficiency, 750 Watts at 92% or 94% efficiency, to 1200 Watts at 90% efficiency. Be sure to use the HPE Power Advisor program for selecting the power supply that best meets your needs.Reduce, Reclaim, Recover. Improve your capacity up to 3X with HPE Dynamic Power Capping and Insight Control. Dynamic Power Capping allows you to cap the servers power use level, without impacting performance and still fully protecting the system Circuit Breakers.Delivering Common Slot/Right-Sized Gold and Platinum power supplies for your needs with the highest efficiency in the industry, as seen by meeting Climate Savers Computing Gold, 80PLUS Gold and Platinum, and setting the standards for Energy Star for Servers compliance.
  • Simplified Server Management
    Clean, tool-free, mechanical design enhances reliability and simplifies configuration and maintenance with tool-free, modular components, hot plug redundancy features for fast maintenance, and minimal cables for easy access to components.With universal tool-free sliding rails the DL360 G7 is quick to install and quick release levers allow for fast server access. An ambidextrous cable management arm option provides cabling flexibility and management for quick access to the server.The focus on Server Commonality increases IT productivity and manageability with universal drives, Smart Array Controllers, and common power supplies and components to simplify spare parts inventories.ROM based configuration and management features increase uptime and simplify configuration and independent health monitoring.
HPE ProLiant DL360 G7 - rack-mountable - Xeon E5606 2.13 GHz - 6 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5606 / 2.13 GHz (Quad-Core)
Processor Socket
LGA1366 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology, Intel Smart Cache
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
6 GB (installed) / 384 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
ATI ES1000
Video Memory
32 MB
GigE
Power Redundancy
Optional
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
42.6 cm x 69.2 cm x 4.3 cm
14.5 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Intel Xeon E5606
Clock Speed
2.13 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1366 Socket
Chipset Type
Intel 5520
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
6 GB / 384 GB (max)
Effective Memory Speed
1066 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
18 (Total) / 15 (empty)
Registered
Configuration Features
3 x 2 GB
RAM Supported
384 GB registered - Advanced ECC , 48 GB unbuffered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
Smart Array P410i
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
256 MB
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Video Memory
32 MB
Integrated
Interface (Bus) Type
PCI Express x4
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
2 x HP NC382i
Remote Management Controller
Integrated Lights-Out 3
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
4 (total) / 4 (free) x hot-swap 2.5" SFF , 1 (total) / 0 (free) x external 5.25" Slim Line
Slots
1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile , 1 (total) / 1 (free) x SD card
1 x serial , 2 x display / video (1 in front) , 3 x USB 2.0 (1 front, 2 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
460 Watt
Operating System / Software
OS Certified
SunSoft Solaris, SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
42.6 cm
69.2 cm
4.3 cm
14.5 kg
10 °C
35 °C
10 - 90% (non-condensing)
7GZ0 HPE Installation Service - installation / configuration In Stock £388.49
Resources
The following resources are available for the HPE HP DL360 G7, Dual Processor Capable, 1 x Xeon E5606 (2.13Ghz)
