The HP ProLiant DL320 G6 Server is an enterprise rack-optimized server at an entry level price. The highly manageable single processor, 1U server is ideal for single-application IT infrastructure, web and edge-of-network applications. The remote console and virtual KVM offered by the embedded ProLiant Onboard Administrator powered by Integrated Lights-Out 2, coupled with the management features of SIM and deployment capabilities of SmartStart and other ProLiant Essentials software, give the DL320 G6 enterprise-class management features. Support for one or two low-cost Serial ATA drives on an integrated RAID0/1 controller, with an optional upgrade to highly reliable hot plug SAS hard drives, gives the DL320 G6 flexibility to meet the needs of your datacenter. Plus, you get the cost-effective solution of a single-processor platform with options from the new Intel Xeon Processor 3000 sequence with turbo mode.
Low Cost, Enterprise Class Rack-Dense Platform
1U, 24-inch (60.96 cm) deep chassis.Spring-loaded Universal sliding rails included.Dedicated application server support for: Up to 2.53 Intel Xeon 2 core (40, 60, 80, 95 and 130 Watts) processors with Turbo Mode Up to 1333FSB DDR3 1333MHz DIMMS.Standard support for four 3.5-inch Serial ATA (SATA) hard drives (8 SFF optional).Support for the latest Microsoft Windows, Novell and Red Hat Linux operating systems. -
Enterprise Class Monitoring and Management
ProLiant Onboard Administrator powered by Integrated Lights-Out 2 server management, which provides virtual presence and control of your servers over the network, is embedded.Fully integrated hardware-based management without needing additional plug-in adapters.SmartStart deployment tool to radically simplifies server deployment.HP Systems Insight Manager (SIM), the world's leading server management tool.Tool-free entry and easy access to critical system components makes it simple to maintain your server. -
Flexible Storage Options
Support for up to four 3.5-inch Serial ATA (SATA) hard drives, plus an integrated SATA controller that supports RAID 0 or RAID 1. SATA hard drive options from low-cost 80GB hard drives to massive 1TB hard drives.Optional support for hot plug SATA or Serial Attached SCSI (SAS) hard drives when using an optional HBA (Host Bus Adapter) or RAID card, support for hot plug hard drives.
- HPE ProLiant DL320 G6 - rack-mountable - Xeon E5603 1.6 GHz - 2 GB - HDD 500 GB
- Server - rack-mountable - administrator password, power-on password, serial port I/O control, USB port control
- Height (Rack Units)
- 1U
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E5603 / 1.6 GHz (Quad-Core)
- Processor Socket
- LGA1366 Socket
- Processor Main Features
- Intel Smart Cache
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 2 GB (installed) / 24 GB (max) - DDR3 SDRAM - ECC - PC3-10600
- Storage Controller
- SATA (SATA 3Gb/s) (Smart Array B110i)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- HDD 500 GB (hot-swap) - SATA 3Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- ATI ES1000
- Video Memory
- 64 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Windows Server Certified
- This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
- 44.8 cm x 68.2 cm x 4.3 cm
- 11.6 kg
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 1U
- 1-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E5603
- Clock Speed
- 1.6 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Intel Smart Cache
- CPU Socket
- LGA1366 Socket
- Chipset Type
- Intel 5500
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 2 GB / 24 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1066 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 9 (Total) / 8 (empty)
- Unbuffered
- Configuration Features
- 1 x 2 GB
- RAM Supported
- 144 GB registered - ECC , 24 GB unbuffered - ECC
Hard Drive
- HDD - hot-swap
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 3Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- Storage Controller Name
- Smart Array B110i
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ATI ES1000
- Video Memory
- 64 MB
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC326i
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Lights-Out 2
- Wake on LAN (WoL), ACPI support, PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 4 (total) / 3 (free) x hot-swap 3.5" LFF , 1 (total) / 1 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 1 (free) x PCIe x4 - half-length, low-profile (x1 mode) , 1 (total) / 1 (free) x PCIe x16 - full-length (x16 mode) , 1 (total) / 1 (free) x SD card
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x VGA , 6 x USB 2.0 (2 in front) , 2 x LAN (Gigabit Ethernet) (2 in front) , 1 x HPE iLO
- Administrator password, power-on password, serial port I/O control, USB port control
- ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
- Power supply
- Voltage Required
- Power Provided
- 500 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Enterprise Linux
- 44.8 cm
- 68.2 cm
- 4.3 cm
- 11.6 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 51.4 dBA
