The HPE 3100 EI Switch Series enhances security by providing reliable fully, managed Fast Ethernet Layer 2 switches ideal for the access layer of medium and large enterprises. Features include enterprise class quality of service (QoS) and security features including rate limiting, QinQ, ACLs, a 24-port PoE model, and improved reliability with backup redundancy. The 3100 EI Switch Series can be managed with the optional HPE Intelligent Management Center (IMC) Software Platform for a single view of your entire network.
Reliable Fast Ethernet Access Layer Switches
The HPE 3100 EI Switch Series enhances security by providing reliable fully managed Fast Ethernet Layer 2 switches ideal for the access layer of medium and large enterprises.Series includes 8-, 16-, 24- and 48-port models with Gigabit Ethernet uplinks with a 24-port PoE model for support of IP phones, wireless APs and video cameras.Hardware-based wire speed access control lists (ACLs) help provide high levels of security and ease of administration without impacting network performance with a feature-rich TCAM-based ACL implementation.External redundant power supply provides improved reliability. -
Enhanced Quality of Service (QoS) and Service Control
The HPE 3100 EI Switch Series provides traffic prioritization with supported congestion actions including strict priority (SP), weighted round robin (WRR), SP+WRR and HQ+WRR queuing.Broadcast control cuts down on unwanted network broadcast traffic. Advanced QoS classifies traffic using multiple match criteria based on Layer 2, 3, and 4 information and applies QoS policies such as setting priority level and rate limit to selected traffic on a per-port or per-VLAN basis.Multiple user authentication methods include MAC Authentication, IEEE 802.1X and Web for greater, policy-driven security.Enhanced security features include port isolation, STP BPDU port protection and root guard. Radius/HWTACAS eases switch management security administration by using a password authentication server. -
Single View of the Network
The HPE 3100 EI Switch Series can be seamlessly managed with the optional HPE Intelligent Management Center (IMC) Software Platform to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.
- HPE 3100-24-PoE v2 EI Switch - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 (PoE) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- Performance
- Throughput: up to 6.5 Mpps , Routing/switching capacity: 8.8 Gbps
- Remote Management Protocol
- SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTPS, CLI
- Flow control, DHCP support, PoE, ARP support, VLAN support, IGMP snooping, WRR queuing, IPv6 support, VCT technology, ACL support, QoS, RADIUS support, MLD snooping, DLDP support, STP Root Guard, LLDP support, Port Security, IP-MAC binding, dynamic ARP protection, DHCP protection, MVR, GVRP, SPQ, port isolation
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 42 cm x 4.36 cm
- 6.5 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- Performance
- Max Units In A Stack
- 16
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, Secure Shell v.2 (SSH2)
- RAM
- 128 MB SDRAM
- Flash Memory
- 16 MB
- 24 x 100Base-TX RJ-45 PoE , 1 x console RJ-45 management , 2 x 1000Base-TX RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- CISPR 22 Class A, GOST, EN 61000-3-2, NOM, VCCI Class A ITE, EN 61000-3-3, EN55022 Class A, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, ICES-003 Class A, EN 61000-4-5, EN 61000-4-11, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, EN 60825-1, FCC Part 15 B Class A, ANSI C63.4, EN 60825-2, EN 300 386, CAN/CSA-C22.2 No. 60950-1
- 44 cm
- 42 cm
- 4.36 cm
- 6.5 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% (non-condensing)
