HPE DL385 G7 SP6176SE 12MB 16GB HPL SFF RAID P41
Quicklinx: 70YGWS00 Mfr#: 604642-425
  • Opteron
  • Red Hat Enterprise Linux
  • DVD-RW
Designed with virtualization in mind, the DL385 G7 server features powerful processor and is ideal for demanding workloads that require high levels of performance. The DL385 G7 server comes with internal USB, plenty of PCI expansion slots and internal storage, making it well suited for a wide range of applications and environments.
As always, you can rely on ProLiant for the best in industry-standard management and Trusted Platform Module (TPM) support - all designed to give you the confidence in your business and the ability to squeeze every bit of productivity out of your server infrastructure.
So although the DL385 G7 server is ideal for virtualization, its flexibility makes it the right fit for any business need, from small businesses to complex dynamic enterprise environments. The perfect balance of price/performance, flexibility, expandability, reliability, and energy efficiency, makes the DL385 G7 server cost-effective.
  • Double Down on Performance
    Latest AMD Opteron 6200 Series 16, 12, 8 and 4 Core processors.Integrated network interconnects to free up PCI slots and support more virtual machines.Up to 24 DIMM slots supporting up to 512 GB of DDR3 Memory.
  • The Right Fit
    With up to six available PCI slots, choose from three modular configurations, including high wattage x16, legacy PCI-X, and (2) x8 dual port risers.8 or 16 SFF SAS hard drives with up to 16 TB, or 6 LFF hard drives for up to 18 TB of internal storage.Choose from 460W AC, 750W AC , 1200W AC or -48V DC power supplies, 92% or 94% Efficiency.Embedded Modular SmartArray storage controllers and your choice of cache size and BBWC or FBWC options.
  • Virtual Perfection
    Robust memory and NIC features to support more virtual machines and compute intensive business needs.HPE Insight Control tools allows you to manage both physical and virtual IT through a single console.Get virtual machines deployed easily and securely.
  • Focus on Energy Efficiency
    92% and new 94% efficiency power supplies saves energy costs.HPE Thermal Logic provides robust power management.
HP ProLiant DL385 G7 - Opteron 6176 SE 2.3 GHz
Server
Rack-mountable - 2U
44.5 cm x 70 cm x 8.6 cm
Server Scalability
2-way
1 x AMD Opteron 6176 SE / 2.3 GHz ( 12-core )
Cache Memory
12 MB L3 Cache
Cache Per Processor
12 MB
RAM
16 GB (installed) / 256 GB (max) - DDR3 SDRAM - Advanced ECC
Storage Controller
RAID ( Serial ATA-300 / SAS 2.0 ) - PCI Express 2.0 x8 ( Smart Array P410i )
Server Storage Bays
Hot-swap 2.5"
Hard Drive
None.
Optical Storage
DVD-RW
Monitor
None.
Graphics Controller
ATI ES1000
Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet - Ethernet Ports : 4 x Gigabit Ethernet
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
3 years warranty - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
44.5 cm
70 cm
8.6 cm
Multi-Core Technology
12-core
64-bit Computing
Installed Qty
1
Max Supported Qty
2
Upgradability
Upgradable
Cache Memory
L3 Cache
Installed Size
12 MB
Cache Per Processor
12 MB
Mainboard
Chipset Type
AMD SR5690/SP5100
RAM
Installed Size
16 GB / 256 GB (max)
DIMM 240-pin
Registered
Configuration Features
8 x 2 GB
RAM Supported
256 GB - registered , 64 GB - unbuffered
Storage Controller
1 x RAID - plug-in card - PCI Express 2.0 x8
Controller Interface Type
Storage Controller Name
Smart Array P410i
Buffer Size
256 MB
Storage
Hard Drive
None.
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor / Vendor
ATI ES1000
Network adapter - integrated
Ethernet Ports
Ethernet Controller(s)
2 x HP NC382i
Remote Management Controller
Integrated Lights-Out 3
Wake on LAN (WoL), ACPI support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" SFF , 1 (total) / 0 (free) x front accessible
Expansion Slot(s)
2 (total) / 1 (free) x PCI Express 2.0 x8 - half-length, full-height ( x4 mode ) , 1 (total) / 1 (free) x PCI Express 2.0 x16 - full-length, full-height ( x8 mode ) , 2 (total) / 1 (free) x processor , 24 (total) / 16 (free) x memory - DIMM 240-pin
1 x serial - RS-232 - 9 pin D-Sub (DB-9) , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 2 x display / video - VGA - 15 pin HD D-Sub (HD-15) ( 1 front, 1 rear ) , 4 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x management - HP iLO - RJ-45 , 4 x Hi-Speed USB - 4 PIN USB Type A ( 2 front, 2 rear )
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
Power supply - hot-plug
Operating System / Software
OS Certified
SuSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Enterprise Linux
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years - on-site
10 °C
35 °C
10 - 90%
Resources
The following resources are available for the HPE DL385 G7 SP6176SE 12MB 16GB HPL SFF RAID P41
