HP DL380e Gen8 8 SFF HDD Cage Kit; 63.5 mm (2.5 "); 910 g; 101.6 mm; 266.7 mm (668295-B21)
ProLiant DL380e Gen8 (2.5"), DL380e Gen8 Base (2.5"), DL380e Gen8 Entry (2.5"), DL380e Gen8 High Performance (2.5"), DL380e Gen8 Storage (2.5")
0.91 kg
Minimum dimensions (W x D x H)
10.16 x 26.67 x 20.32 cm
- HPE SFF Hot Plug Hard Drive Cage Kit - storage drive cage
- Storage drive cage
- Expansion Bays
- 8 x hot-swap - 2.5" SFF
- Hard Drive Form Factor Compatibility
- 2.5"
- Designed For
- ProLiant DL380e Gen8 (2.5"), DL380e Gen8 Base (2.5"), DL380e Gen8 Entry (2.5"), DL380e Gen8 High Performance (2.5"), DL380e Gen8 Storage (2.5")
- 2.5"
Storage Controller
- Processor
- No CPU
- Bays
- Designed For
- HPE ProLiant DL380e Gen8 (2.5"), DL380e Gen8 Base (2.5"), DL380e Gen8 Entry (2.5"), DL380e Gen8 High Performance (2.5"), DL380e Gen8 Storage (2.5")
