Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
Designed and Engineered to Provide Reliable and Cost Efficient Data Storage
The HPE Server SATA Hard Drives increase reliability and lower start-up costs without sacrificing reliability with non-mission critical hard drives at the lowest $/GB.Both cost and capacity optimized solutions provide up to 10 TB of storage in a single device. Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) that are available in a wide variety of capacity points.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.6 Gb/sec data transfer rate supporting existing servers.
- HPE Midline - hard drive - 500 GB - SATA 3Gb/s
- Hard drive - hot-swap
- Capacity
- 500 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ)
- 1-year warranty
- Designed For
- ProLiant DL120 G6, DL120 G7, DL160 G5, DL160 G5p, DL160 G6, DL160se G6, DL165 G5, DL165 G5p, DL165 G6, DL165 G7, DL180 G5, DL180 G6, DL185 G5, DL320 G5p, DL320 G6, DL320s, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, ML110 G7, ML150 G5, ML150 G6, ML310 G5, ML310 G5p, ML330 G6, ML350 G5, ML350 G6, ML370 G6
- Capacity
- 500 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 3Gb/s
Performance
- Drive Transfer Rate
- 300 MBps (external)
- Seek Time
- 8.5 ms (average) / 17 ms (max)
- Track-to-Track Seek Time
- 1 ms
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 3 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Limited warranty - parts and labour - 1 year
- 5 °C
- 55 °C
- Designed For
- HPE ProLiant DL120 G6 Base (3.5"), DL120 G7 (3.5"), DL120 G7 Base (3.5"), DL120 G7 Entry (3.5"), DL120 G7 Performance (3.5"), DL160 G5 (3.5"), DL160 G5p (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G5 (3.5"), DL165 G5 Special Server (3.5"), DL165 G5p Base (3.5"), DL165 G5p Performance (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry (3.5"), DL180 G5 (3.5"), DL180 G5 Special Server (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL185 G5 (3.5"), DL185 G5 Special Server (3.5"), DL320 G5p (3.5"), DL320 G6 (3.5"), DL320 G6 Entry (3.5"), DL320 G6 High Efficiency (3.5"), DL320 G6 Performance (3.5"), DL320s (3.5"), DL370 G6 (3.5"), DL380 G6 (3.5"), DL380 G7 (3.5"), DL385 G6 (3.5"), DL385 G6 ICE Performance (3.5"), DL385 G7 (3.5"), ML110 G7 (3.5"), ML110 G7 Performance (3.5"), ML150 G5 (3.5"), ML150 G5 Base (3.5"), ML150 G5 Performance (3.5"), ML150 G6 (3.5"), ML150 G6 Base (3.5"), ML150 G6 Performance (3.5"), ML310 G5 (3.5"), ML310 G5p (3.5"), ML330 G6 (3.5"), ML330 G6 Base (3.5"), ML330 G6 Entry (3.5"), ML350 G5 (3.5"), ML350 G5 Entry (3.5"), ML350 G6 (3.5"), ML350 G6 Entry (3.5"), ML370 G6 (3.5")
