Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
Designed and Engineered to Provide High Capacity and Reliable Secure Storage
HPE Server Midline Hard Drives are ideal for bulk data storage, cloud and web infrastructure environments.Broad portfolio of optimized solutions provide up to 10 TB of storage, and growing in a single device.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) in a wide variety of capacity points.Prevent unauthorized access to your data with HPE Digitally Signed Firmware. It provides the security and assurance that drive firmware comes from a trusted source and protects against malicious attacks. -
Support Entry/SMB servers with value priced drives
HPE Server Midline Hard Drives have lower start-up costs without sacrificing reliability at the lowest $/GB.Non-mission critical hard drives at the lowest $/GB.6 Gb/sec data transfer rate to support existing servers.
- HPE Midline - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - hot-swap
- Capacity
- 500 GB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 7200 rpm
- 1-year warranty
- Bundled with
- HPE SmartDrive carrier
- Designed For
- ProLiant DL320e Gen8, DL360e Gen8, DL380e Gen8, DL385p Gen8, ML310e Gen8, ML350e Gen8
- Capacity
- 500 GB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" LFF
- Limited warranty - 1 year
- Designed For
