Product
Brand
HPE 300GB 6G SAS 10K SFF DP ENT HD
Quicklinx: 5HYPWS00 Mfr#: 507127-B21
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Dual Port Enterprise - hard drive - 300 GB - SAS 6Gb/s
Hard drive - hot-swap
300 GB
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
10000 rpm
7.9 cm x 13.8 cm x 1.6 cm
3 years warranty
Modular Smart Array P2000 G3; ProLiant BL460c G7, BL620C G7, BL680c G7, BL685c G7, DL165 G7, DL360 G7, DL370 G6, DL380 G7, DL580 G5, DL585 G5, DL980 G7, ML110 G7; StorageWorks D2200, X1600, X1600 3TB, X1600 G2, X1800, X1800 G2, X3800sb G2; StorageWorks Network Storage Blade X1800sb G2
300 GB
2.5" SFF
SAS 6Gb/s
Bytes per Sector
512
7.9 cm
13.8 cm
1.6 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
4 ms (average) / 7.45 ms (max)
Track-to-Track Seek Time
0.2 ms
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 3 years
10 °C
35 °C
HP Integrity BL860c i2, BL870c i2, BL890c i2 , HP Modular Smart Array P2000 G3 FC MSA Dual Controller Virtualization SAN Starter Kit , HP ProLiant BL460c G6, BL460c G7, BL465c G6, BL465c G7, BL620C G7, BL680c G7, BL685c G6, BL685c G7, DL160 G6, DL160se G6, DL165 G7, DL165 G7 Performance, DL180 G6, DL320 G6, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G5 Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML110 G7, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, WS460c G6 Workstation Blade , HP StorageWorks D2200sb PCIe Storage Blade , HP StorageWorks Disk Enclosure D2700 , HP StorageWorks Modular Smart Array 2324fc G2 Dual Controller, 2324sa G2 DL380 G6 Package Cluster, 2324sa G2 Dual Controller, 70 Dual Domain, P2000 2.5-in Drive Bay Chassis, P2000 G3 FC/iSCSI Dual Combo Controller SFF Array , HP StorageWorks Network Storage Blade X1800sb G2 , HP StorageWorks Network Storage Gateway X3800sb G2 , HP StorageWorks Network Storage System X1600, X1600 292GB SAS Model, X1600 3TB SAS Model, X1600 5.4TB SAS Model, X1600 7.5TB SAS Model, X1600 G2, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 G2
