Introducing HP's most powerful detachable PC. With remarkable performance and versatility to push your favorite Adobe applications to the limit, no PC is better suited to turn your vision into reality.
Windows 10 Pro for Workstations
Be productive in any situation. Windows 10 Pro for Workstations and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook x2. -
HP DreamColor Display
Immerse yourself in 1 billion colors on a stunning, 4K, multi-touch display. Work in any lighting with the anti-glare touchscreen - HP's most advanced detachable PC display. -
HP Quick Keys for short deadlines
Work quickly and comfortably with 18 equivalent shortcuts at your fingertips, customized for all your favorite Adobe applications. -
Bluetooth, full-performance detachable keyboard
The full-sized keyboard is Bluetooth -enabled to stay active when detached, so you have access to shortcut key combinations when working in appications like Adobe Photoshop . -
Sleek and Portable Design
Experience the intersection of mobility & performance in a fully-machined, aluminum and die-cast magnesium body starting at just 3.59 pounds and 14.6 mm thin when in tablet mode. -
NVIDIA Quadro 3D Graphics
Professional graphics performance that delivers real-time visualization of multi-layered artwork and creative projects.
- HP ZBook x2 G4 Detachable Workstation - 14" - Intel Core i7 - 7500U - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Tablet - with Bluetooth keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 14" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K
- Graphics
- NVIDIA Quadro M620 / Intel HD Graphics 620
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Detachable keyboard
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 4.2
- Battery
- 4-cell - up to 10 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Dimensions (WxDxH) - tablet
- 36.45 cm x 22.7 cm x 1.46 cm
- 1.65 kg
- Localisation
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7500U / 2.7 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 3840 x 2160 (Ultra HD 4K)
- Widescreen
- Image Brightness
- 300 cd/m²
- Colour Support
- 1 billion colours
- High Bit Rate 2 (HBR2), Ultra HD 4K ultra wide-viewing angle (UWVA) anti-glare DreamColor
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus, Shader Model 5.0
- Camera
- Yes - 720p (front)
- Resolution
- 8 Megapixel (rear)
- Video Resolutions
- 1280 x 720, 1920 x 1080
- Frame Rate
- 30 frames per second
- Camera Features
- IR camera, low light enhancement, rear camera with auto focus, front camera with fixed focus
- Sound
- Stereo speakers, dual array microphone
- Codec
- Conexant CX7700
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio, Intel Smart Sound
Input
- Keyboard Layout
- UK
- Volume control, ClickPad with gesture support, brightness adjustment, on/off touch, kickstand, HP Quick Key
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
- Miracast
- IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell lithium polymer
- Capacity
- 70 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 90 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.0 (charging) , 2 x USB-C 3.1 (supports Thunderbolt 3, DisplayPort 1.2, VGA, HDMI) (Power Delivery) , Headphone/microphone combo jack , HDMI
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Security
- Power-on password, Intel Anti-Theft Technology (iAT), HP SpareKey, One-Step Logon, Setup Password, Automatic DriveLock, HP Drive Encryption, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MST (multi-stream transport), Master Boot Record Security, Secure Erase
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion sensor
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, Bluetooth keyboard
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, A-Tick, ICES
- Localization
- 1.65 kg
- Dimensions (WxDxH) / Weight Details
- 36.45 cm x 22.7 cm x 1.46 cm / 1.65 kg - tablet , 36.45 cm x 22.7 cm x 2.03 cm / 2.17 kg - tablet with keyboard
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (8)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £22.69 |
HP 65W Smart AC Adapter | In Stock | £18.54 |
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE | In Stock | £33.61 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £135.29 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £188.99 |
HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook | In Stock | £41.06 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £123.81 |
Other bundles (10)
HPE DisplayPort to HDMI Adapter | In Stock | £13.44 |
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HPE HP DisplayPort to DVI Adapter | In Stock | £17.23 |
HPE DisplayPort to VGA Adapter | In Stock | £16.40 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.58 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
