HP 65W Smart AC Adapter
Quicklinx: C872WS00 Mfr#: H6Y89AA#ABU
More than 50 In Stock
£18.54 ex VAT
£22.24 inc VAT
Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
  • Easy to use
    Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
  • Power up wherever you work
    Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
  • World-class support
    Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
HP Smart AC Adapter - power adapter - 65 Watt
Power adapter - external
280 g
English / United Kingdom
Output Voltage
18.5 V
Power Capacity
65 Watt
Output connectors
1 x power DC jack 4.5 mm
4.5mm to 7.4mm power DC dongle
10.6 cm x 4.7 cm x 2.8 cm
HP 245 G7; EliteBook 830 G6, 84XX, 85XX, 87XX; Laptop 15; ProBook 11 G1, 430 G3, 430 G4, 430 G7, 440 G4, 440 G5, 440 G7, 445r G6, 450 G7, 455 G3, 455 G5, 455r G6, 45X G4, 470 G0, 470 G3, 470 G4, 470 G5, 635, 640 G5, 645 G3, 645 G4, 650 G5, 655 G2; ZBook 14u G4, 14u G5, 14u G6, 15u G2, 15u G3, 15u G6
Input Voltage Range
AC 90 - 265 V
Frequency Required
47 - 63 Hz
Output Voltage
18.5 V
Power Capacity
65 Watt
Power cable , Power connector adaptor
Over voltage protection
CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
5 °C
35 °C
10.6 cm
4.7 cm
2.8 cm
280 g
Shipping Weight
0.6 kg
HP 215 G1 Notebook, 240 G1 Notebook, 240 G2 Notebook, 245 G1 Notebook, 245 G2 Notebook, 245 G7 Notebook, 248 G1 Notebook, 255 G2 Notebook, 255 G5 Notebook, 256 G8 Notebook, 3005pr USB 3.0 Port Replicator, 340 G1 Notebook, 340 G2 Notebook, 340 G5 Notebook, 340 G7 Notebook, 340S G7 Notebook, 348 G5 Notebook, 450, 455, 470 G7 Notebook, 631, 636, 650, 655 , HP Chromebook 11 G5, 13 G1, 14, 14 G4 , HP Chromebox Enterprise G3 , HP EliteBook 725 G3 Notebook, 725 G4 Notebook, 735 G5 Notebook, 735 G6 Notebook, 745 G4 Notebook, 745 G5, 745 G5 Notebook, 745 G6 Notebook, 755 G2 Notebook, 755 G3 Notebook, 830 G5, 830 G6, 830 G6 Notebook, 840 G5, 840 G6, 840 G6 Notebook, 840r G4 Notebook, 8440w Mobile Workstation, 8460w Mobile Workstation, 8470w Mobile Workstation, 850 G3 Notebook, 850 G6 Notebook, 8530p Notebook, 8570p Notebook, 8730p Notebook, 8740p Notebook , HP EliteBook Folio 1020 G1, 1040 G2 , HP EliteBook Revolve 810 G1 Tablet , HP EliteBook x360 830 G6 Notebook , HP Laptop 15-dw4030nm , HP Mobile Thin Client mt32, mt40, mt41, mt45 , HP ProBook 11 G1 Notebook, 430 G3 Notebook, 430 G4 Notebook, 430 G7 Notebook, 4340s, 440 G4 Notebook, 440 G5 Notebook, 440 G7 Education Edition Notebook, 440 G7 Notebook, 445r G6 Notebook, 450 G4 Notebook, 450 G7 Notebook, 455 G3 Notebook, 455 G4 Notebook, 455 G5 Notebook, 455r G6 Notebook, 470 G0 Notebook, 470 G3 Notebook, 470 G4 Notebook, 470 G5 Notebook, 635 Aero G8 Notebook, 640 G5 Notebook, 645 G3 Notebook, 645 G4 Notebook, 6470b, 6475b, 650 G5 Notebook, 655 G2 Notebook , HP ProBook x360 11 G5 Education Edition Notebook, 11 G7 Education Edition Notebook, 435 G8 Notebook , HP Spectre Laptop 13 Pro , HP Spectre Pro x360 G1, x360 G2 , HP Spectre x2 Pro 13 , HP Stream Pro Laptop 11 G3 , HP ZBook 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G6 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
