Be ready when inspiration strikes. Packed with professional performance in an incredibly sleek PC that comfortably fits in your bag, the ZBook Studio is engineered to get you in the zone and help you stay focused. Now you can build complex assemblies, render in real time or visualize data-from anywhere.
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
HP Fast Charge
Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes. -
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup. -
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
- HP ZBook Studio G9 Mobile Workstation - 16" - Intel Core i7 - 12800H - vPro - 32 GB RAM - 1 TB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (12th Gen) - 12800H / 2.4 GHz, up to 4.8 GHz / 24 MB Cache
- Memory
- 32 GB DDR5 (2 x 16 GB)
- Storage
- 1 TB SSD - NVMe, TLC
- Display
- 16" WLED 1920 x 1200 / WUXGA
- Graphics
- NVIDIA RTX A2000 / Intel Iris Xe Graphics
- Video Memory
- 8 GB GDDR6 SDRAM
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.2
- Battery
- 6-cell
- Tile module, HP Tamper Lock
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Nouvelle silver
- 35.6 cm x 24.2 cm x 1.9 cm
- 1.73 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 12800H / 2.4 GHz
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- 14-core
- Cache
- L3 - 24 MB
- Intel Turbo Boost Max Technology 3.0, Hyper-Threading Technology, Intel Smart Cache
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM - non-ECC
- Speed
- 4800 MHz
- Rated Speed
- 4800 MHz
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 1 TB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
- 16" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1200 (WUXGA)
- Widescreen
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 100% sRGB
- Anti-glare, WUXGA ultra wide-viewing angle (UWVA), narrow bezel bent
- Keyboard Name
- HP Premium Quiet Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 8 GB GDDR6 SDRAM
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Four speakers, HP World Facing Microphone / dual-array digital microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Gesture function, multi-touch clickpad, volume control, DuraKeys, spill-resistant
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 211
- Dual stream (2x2), Miracast
- Technology
- 6-cell lithium polymer
- Capacity
- 86 Wh
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 150 watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , 2 x USB-C 3.2 Gen 2 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery, Sleep & Charge) , DisplayPort
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- HP Device Access Manager, Windows Defender, HP Manageability & Integration Kit, HP BIOSphere Gen6, HP Sure Admin, HP Image Assistant, HP Client Security Manager Gen7, HP Smart Support, HP Power Manager, HP Hotkey Support, HP Noise Cancellation Software, HP Performance Advisor, HP Support Assistant, HP Connection Optimizer, HP Privacy Settings, HP QuickDrop, Data Science Stack, HP Easy Clean, HP PC Hardware Diagnostics, HP ZCentral Remote Boost 2020 Software for Z workstation (free download), HP Z Light Space
- Nouvelle silver
- Integrated Options
- Security
- BIOS Absolute Persistence, Power On Authentication, Master Boot Record Security, Pre-boot Authentication, HP Sure Start Gen 6
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 150W Slim Smart AC Adapter
- Low halogen
- Localization
- 1.73 kg
Sustainability Information
- ENERGY STAR Certified
HP USB-C To VGA Adapter | In Stock | £23.07 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.48 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £208.06 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £216.07 |
Poly DA75 Sound Card | In Stock | £27.52 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £103.25 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £108.17 |
Poly TRIO C60 EXPANSION MICROPHONES | In Stock | £147.98 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £67.33 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £43.34 |
Poly EncorePro HW510 Mono Headset (N/C) | In Stock | £70.13 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £111.53 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £103.25 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £117.00 |
Poly Voyager 4320 UC V4320 C USB-C CS WW | In Stock | £117.00 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £111.68 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £108.17 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £103.25 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £98.17 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £111.00 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £55.47 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £87.67 |
Poly Sync 40 SY40-M WW | In Stock | £123.47 |
Poly EncorePro 525 USB EP525-M USB-A Headset | In Stock | £90.57 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £109.67 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £29.68 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £29.68 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £68.27 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £45.23 |
Poly Blackwire 3210 headset - on-ear - wired - USB-C - black | In Stock | £25.87 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £59.09 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £29.67 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.27 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £24.80 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £77.77 |
Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black | In Stock | £68.08 |
