Poly EncorePro 515-M headset - on-ear - wired - USB-A - black
Quicklinx: HY47WS00 Mfr#: 783R1AA
Recommended Use: Computer
Connectivity: Wired
£77.77 ex VAT
£93.32 inc VAT
Unleash your call center productivity with the EncorePro 500 Series headsets. Connecting your headset to your PC, from home or the office, is easy with multiple options. And with the lightweight and comfy design, your agents will stay engaged.
  • Noise canceling microphone
    Next-generation flexible microphone, with positioning guides, reduces background noise and interference, ensuring fewer missed words and a better caller experience.
  • Easy management via Poly Lens
    Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software.
  • Connection flexibility
    Easily answer calls from your PC, regardless of the type of USB port you have, thanks to the convenient built-in USB-A and USB Type-C ? connectors on the same cable.
  • Certified for Microsoft Teams
    Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
  • Acoustic hearing protection
    SoundGuard DIGITAL uses sophisticated algorithms to provide additional acoustic protection, above and beyond the impulse and long duration protection provided by SoundGuard while maintaining natural sounding speech.
Poly EncorePro 515-M - headset - USB-A
Headset - wired - USB-A
Compatibility
Windows, Mac
Recommended Use
Computer
Headphones Form Factor
On-ear monaural
Wired
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end
Software Certification
Series
EncorePro 500 series
Compatibility
Windows, Mac
11.1 cm
14.9 cm
6.7 cm
52 g
Earpad Material
Artificial leather
Recommended Use
Computer
Boom mic length 135mm, 290° rotatable microphone
Audio Output
On-ear monaural
Wired
Frequency Response
20 - 20000 Hz
Diaphragm
5.6 mm
Microphone
Boom
Omni-directional
Sensitivity
40 dB
Sensitivity Margin
+/- 3dB
Frequency Response
35 - 21000 Hz
Signal-To-Noise Ratio
53 dB
Remote Control
Controls
Connector Type
USB (USB Type-A)
Cable
Cable Length
2.085 m
Supported Host Device OS
Windows, macOS
Shipping Width
19 cm
Shipping Depth
17.5 cm
Shipping Height
5.5 cm
Shipping Weight
150 g
HY47 Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.14
HY47 Poly DA85-M Sound Card In Stock £44.59
HY47 Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.62
HY47 Poly HIS Adapter Cable In Stock £24.75
HY47 Poly Ear cushion for Poly EncorePro HW530, HW540 In Stock £2.51
HY47 Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro In Stock £10.80
Connectivity: Wired
Brand: Poly
