HP ZBook Power G9 Intel Core i7-12700H 16GB 512GB SSD 15.6" Windows 11 Professional
Quicklinx: H7LWWS00 Mfr#: 69Q54EA#ABU
£1,329.79 ex VAT
£1,595.74 inc VAT
Upgrade to professional ZBook performance and security at an unbelievably affordable price. Power up your productivity on this durable yet premium device-delivering enhanced collaboration features and pro-grade components to seamlessly run leading professional software applications.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • 15.6" (39.6 cm) Diagonal FHD Display
    Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • HP Collaboration Keyboard
    Launch and manage calls from anywhere using Skype with HP Noise Cancellation and the world-facing third microphone. Shortcut keys, including start/stop call, calendar and screen share, enable efficient and effective collaboration.
  • Industry-leading security features
    Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
HP ZBook Power G9 Mobile Workstation - 15.6" - Intel Core i7 - 12700H - vPro - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 11 Pro - English
Platform Technology
Intel vPro Platform
Intel Core i7 (12th Gen) - 12700H up to 4.7 GHz / 24 MB Cache
16 GB DDR5 (1 x 16 GB)
Storage
512 GB SSD - NVMe, TLC
Display
15.6" WLED 1920 x 1080 / Full HD @ 60 Hz
Graphics
NVIDIA RTX A1000 / Intel Iris Xe Graphics
Video Memory
4 GB GDDR6 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
6-cell
Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor, HP Tamper Lock
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
35.94 cm x 23.39 cm x 2.28 cm
1.9 kg
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Mobile workstation
Operating System
Windows 11 Pro - English
Processor / Chipset
CPU
Intel Core i7 (12th Gen) 12700H
Max Turbo Speed
4.7 GHz
Number of Cores
14-core
Cache
L3 - 24 MB
Platform Technology
Intel vPro Platform
Hyper-Threading Technology, Intel Turbo Boost Technology, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM
Speed
4800 MHz
Rated Speed
4800 MHz
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
400 cd/m²
Colour Gamut
72% NTSC
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR2, narrow bezel bent
Keyboard Name
HP Premium
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Camera cover
Sound
Dual stereo speakers, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Programmable buttons, volume control, spill-resistant, multi-touch clickpad, gesture function, precision touchpad, glass clickpad, DuraKeys
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 1216
Network Interface
Gigabit Ethernet
Miracast, CNVi
6-cell lithium polymer
83 Wh
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
150 Watt
Connections & Expansion
Interfaces Details
USB-C 3.1 Gen 2 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (BC1.2 charging) , HDMI , USB 3.2 Gen 1 (charging) , Headphone/microphone combo jack , LAN , 2 x USB 3.2 Gen 1
Software
Software Included
HP Remote Graphics Software, HP Support Assistant, Bing Toolbar, HP Hotkey Support, HP Performance Advisor, HP Client Catalogue (free download), HP Image Assistant (free download), HP PC Hardware Diagnostics, HP Connection Optimizer, HP Privacy Settings, HP Cloud Recovery, HP Performance Advisor (free download), HP QuickDrop, HP Client Management Script Library (free download), HP Wake on WLAN, HP Noise Cancellation Software, Tile, HP Easy Clean, HP Smart Support, HP ZCentral Remote Boost 2020 Software for Z workstation (free download), Adobe Creative Cloud Bundle, Data Science Stack, HP Driver Packs (free download)
Integrated Options
Security
Intel Active Management Technology (iAMT), Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, BIOS Update via Network, HP Sure Click, HP Sure Sense, HP Secure Erase, HP Sure Start Gen 6, HP Sure Admin, HP Sure Run Gen 4, HP Client Security Manager Gen 7, HP BIOSphere Gen 6, HP Sure Recover Gen 4
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
HP 150 Watt Smart PFC Slim AC Adapter
CSA, VCCI, BSMI, GS, SABS, CCC, FCC, KCC, A-Tick, ICES, EAC, CIT, SEPA, low halogen, ICCP, MIL-STD-810H, BNCI
Localization
1.9 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (7)
Get more from your purchase from one of our essential accessories
H7LW HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £110.93
H7LW HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £140.13
H7LW HP Thunderbolt Dock G4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE In Stock £163.16
H7LW HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.06
H7LW HP Thunderbolt Dock G4 - USB-C / Thunderbolt 4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE In Stock £208.55
H7LW HP Nano - Security Cable Lock In Stock £15.46
H7LW HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £18.55
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
H7LW HP Care Pack NBD Hardware Support for Travelers In Stock £128.29
H7LW HP Care Pack Next Business Day Active Care Service - extended service agreement - 3 years - on-site In Stock £116.99
Other bundles (56)
H7LW HP USB-C To VGA Adapter In Stock £22.09
H7LW HP USB Travel Mouse In Stock £9.11
H7LW HP USB-C to HDMI 2.0 Adapter In Stock £46.71
H7LW HP USB G2 Stereo Headset In Stock £19.85
H7LW HP 128 Wired Mouse In Stock £8.31
H7LW HP P22h G5 P-Series LED Monitor Full HD (1080p) 21.5" In Stock £90.43
H7LW Poly Voyager Focus 2 UC-M C USB-A WW In Stock £99.99
H7LW Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £210.12
H7LW Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £210.12
H7LW Poly P5 1080P HD Webcam In Stock £36.52
H7LW Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £110.08
H7LW Poly Voyager 4320 UC V4320 C USB-C WW In Stock £103.93
H7LW Poly Voyager Focus 2 UC-M USB-A with Stand In Stock £108.52
H7LW Poly TRIO C60 EXPANSION MICROPHONES In Stock £138.06
H7LW Poly Blackwire C3225 USB-A Headset In Stock £51.32
H7LW Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £80.91
H7LW Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.86
H7LW Poly EncorePro HW510 Mono Headset (N/C) In Stock £82.57
H7LW Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
H7LW Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £98.60
H7LW Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £119.36
H7LW Poly Voyager Legend Bluetooth Headset In Stock £53.96
H7LW Poly Voyager 4310 UC V4310-M C USB-A WW In Stock £100.17
H7LW Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £119.36
H7LW Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £110.60
H7LW Poly Voyager 5200 UC B5200 Headset with Case In Stock £93.27
H7LW Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £110.08
H7LW Poly Voyager 4320 UC V4320 C USB-A WW In Stock £97.00
H7LW Poly Voyager 4310 UC V4310 C USB-A WW In Stock £99.16
H7LW Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £110.08
H7LW Poly EncorePro HW510 Mono Headset (VT) In Stock £71.89
H7LW Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
H7LW Poly Sync 40 SY40-M WW In Stock £124.47
H7LW Poly Voyager Focus 2 UC USB-A Headset with Stand In Stock £143.47
H7LW Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £92.95
H7LW Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £30.29
H7LW Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.99
H7LW Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.01
H7LW Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager In Stock £88.77
H7LW HP OMEN 27" Full HD 165Hz Gaming Monitor In Stock £145.60
H7LW Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.15
H7LW Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £61.81
H7LW Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £27.25
H7LW Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £25.07
H7LW Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £74.89
H7LW HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £320.60
H7LW Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £79.52
H7LW Poly EncorePro 530 - headset - Quick Disconnect In Stock £79.52
H7LW HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £159.91
H7LW Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.95
H7LW Poly EncorePro HW520D - headset - Quick Disconnect In Stock £104.36
H7LW HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £220.57
H7LW Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £49.43
H7LW HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor In Stock £125.72
Brand: HP
Price Range Ex VAT: £1000 - £1500
