Experience a whole new level of performance for your professional workflow. The Z2 Tower is engineered to seamlessly run multi-threaded apps for fast rendering, simulation, and now real-time ray tracing. And when your demands change, you have impressive expandability to upgrade.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
Security is your top priority
The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses. -
Smaller, Functional Design
The stunning new design features front and rear ledges, so you can easily move your system from location to location. -
Tool-less Access
Evolve your work. Evolve your rig. With a tool-less sliding access cover, you can easily get into the the interior, and customize your Z to fit your needs. -
Thermal Management
Innovatively designed to keep hardware components cool and quiet no matter how hard you push it. Have confidence to run your system at max load 24/7.
- HP Workstation Z2 G9 - tower - AI Workstation - Core i7 i7-14700 2.1 GHz - 16 GB - SSD 1 TB - UK - with HP Wolf Pro Security Edition (1 year)
- Workstation - tower - AI Workstation
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Core i7 (14th Gen) i7-14700 / 2.1 GHz (up to 5.4 GHz, (20-core)
- Processor Socket
- LGA1700 Socket
- Processor Main Features
- Intel Turbo Boost Technology
- Cache Memory
- 33 MB L3 Cache
- Cache Per Processor
- 33 MB
- RAM
- 16 GB (installed) / 128 GB (max) - DDR5 SDRAM - non-ECC
- Storage Controller
- SATA/NVMe (SATA 6Gb/s / PCIe 4.0 x4 (NVMe))
- Hard Drive
- SSD 1 TB - PCI Express 4.0 - M.2 2280 - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 770 Unified Memory Architecture (UMA)
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Wi-Fi 6, Bluetooth, Wi-Fi 7
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 11 Pro
- Software Included
- HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Driver Packs, HP Image Assistant, HP PC Hardware Diagnostics, HP System Software Manager (free download), HP Sure Click, HP Manageability Integration Kit, HP Sure Admin, HP Client Security Manager Gen6, HP BIOSphere Gen6, HP ZCentral Remote Boost, HP Sure Recover Gen4, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 4, HP Performance Advisor 3.0, HP Sure Sense Gen2, HP Sure Run Gen5, HP Sure Start Gen7
- Black
- 16.9 cm x 38.5 cm x 35.6 cm
- 7.2 kg
- Limited warranty - parts and labour - 3 years - on-site
- Bundled with
- HP Wolf Pro Security Edition (1 year)
- Workstation
- AI Level
- AI Workstation
- Product Form Factor
- Tower - 4U
- Sensors
- HP Tamper Lock
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
- Bundled with
Processor / Chipset
- CPU
- Intel Core i7 (14th Gen) i7-14700
- Clock Speed
- 2.1 GHz (P-core) / 1.5 GHz (E-core)
- Max Turbo Speed
- 5.4 GHz (P-core) / 4.2 GHz (E-core)
- Number of Cores
- 20-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 28 MB
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1700 Socket
- Chipset Type
- Intel W680
Cache Memory
- Installed Size
- L3 Cache - 33 MB
- 33 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 4800 MHz
- Rated Memory Speed
- 4800 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 1 TB
- Interface Type
- PCI Express 4.0
Storage Controller
- 1 x SATA/NVMe
- Controller Interface Type
- SATA 6Gb/s / PCIe 4.0 x4 (NVMe)
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP 320K
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP 320M
- Interface (Bus) Type
- M.2 2230
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel WI-FI 7 BE200
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6), Bluetooth 5.4, IEEE 802.11be (Wi-Fi 7)
- Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2), Intel Active Management Technology (AMT) 16
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external 5.25" , 1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x PCIe 5.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height (x1 mode, open ended) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height (open ended) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 3 (total) / 2 (free) x M.2 Card - 2280 (PCIe 4.0 x4 mode) , 1 (total) / 0 (free) x M.2 Card - 2230 (PCIe 3.0 x1 mode and Intel CNVi wireless module)
- 1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 6 x USB 3.2 Gen 2 (4 front, 2 rear) (one of them is charging) , 1 x audio line-in , 1 x audio line-out , 2 x DisplayPort 1.4 , 3 x USB 2.0 , 1 x USB 3.2 Gen 1 , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
- Security Slot Type
- Kensington security slot
- RoHS, FIPS 140-2, WEEE, Energy-Related Products (ErP) Lot 6, CECP, SEPA, low halogen
- Power supply
- Voltage Required
- AC 90-269 V (50/60 Hz)
- Power Provided
- 700 watt
- Efficiency
- 92%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 11 Pro English
- Software
- 16.9 cm
- 38.5 cm
- 35.6 cm
- 7.2 kg
- Shipping Width
- 29.5 cm
- Shipping Depth
- 49 cm
- Shipping Height
- 51.8 cm
- 5 °C
- 35 °C
- 10 - 85% RH (non-condensing)
Warranties (2)
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £45.90 |
HP Electronic Care Pack Next Business Day Hardware | In Stock | £32.96 |
Monitors (10)
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £235.36 |
HP P24 G5 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £145.93 |
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £164.32 |
HP HP P24G5 FHD Monitor | In Stock | £145.93 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £491.31 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £165.42 |
HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £76.71 |
HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £115.80 |
HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £82.71 |
HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £259.17 |
Keyboards and Mice (6)
HP 128 Wired Mouse | In Stock | £8.48 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £26.28 |
HP 655 Keyboard and Mouse Set - Wireless | In Stock | £62.95 |
HP 125 - Mouse - wired - USB - black | In Stock | £6.20 |
HP Desktop 320MK - Keyboard and mouse set - full size - USB - UK - black | In Stock | £15.39 |
HP 320K Wired Keyboard | In Stock | £11.78 |
Other bundles (42)
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £208.06 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £208.06 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £108.17 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £106.60 |
Poly TRIO C60 EXPANSION MICROPHONES | In Stock | £144.27 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £65.27 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £108.44 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £117.00 |
Poly Savi 7320 Office S7320 Stereo Headset | In Stock | £242.98 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £98.17 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £115.93 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £106.60 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £98.17 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £108.40 |
Poly EncorePro HW710 Mono Headset (Noise Cancelling) | In Stock | £105.12 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £54.93 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £87.21 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £109.27 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £32.44 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £35.37 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £67.04 |
Poly Savi 8220 headset - on-ear - DECT / Bluetooth - wireless - USB-A via Bluetooth adapter - black | In Stock | £197.26 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £45.04 |
Poly Savi 8420 Office headset - on-ear - DECT / Bluetooth - wireless - active noise cancelling | In Stock | £164.89 |
Poly Savi 8410 Office headset - on-ear - DECT / Bluetooth - wireless - black | In Stock | £190.01 |
Poly Blackwire 3210 headset - on-ear - wired - USB-C - black | In Stock | £25.87 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £61.00 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.93 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.27 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £24.80 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £77.77 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.40 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.57 |
Poly Voyager Focus 2 - headset - USB-C via Bluetooth adapter | In Stock | £144.75 |
Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C | In Stock | £40.91 |
Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C | In Stock | £61.00 |
Poly Blackwire 3220 USB-C HS +USB-C/A Headset | In Stock | £26.96 |
Poly Blackwire 5220 USB-C HS +USB-C/A Headset | In Stock | £63.33 |
Poly Poly Voyager Focus 2 - Headset - On-Ear | In Stock | £136.41 |
