HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor
Quicklinx: J0TWWS00 Mfr#: 169L0AA#ABU
More than 50 In Stock
£165.42 ex VAT
£198.50 inc VAT
Make a great impression on video calls on this 60.45 cm (23.8-inch) full HD conferencing monitor. The integrated, 5MP tilt-adjustable pop-up webcam displays a sharp, detailed picture – even in low light – and the built-in speakers and mic produce clear, life-like sound. Everything you need to present your best self on every call.
  • More Ports. More Flexibility
    Packed with ports including HDMI, DisplayPort , USB-B plus four USB ports.
  • Personalized and Protected
    Personalize brightness and color settings or set up security protocols all without the OSD. With HP Display Center installed, you have the control.
  • Remote Management Reimagined
    HP Client Management Script Library (CMSL) makes remote manageability easy to use. This powerful solution works seamlessly with Intune/SCCM to manage your display fleet using PowerShell.
  • 3-year Limited Warranty
    Get peace of mind with a 3-year warranty.
HP E24mv G4 Conferencing Monitor - E-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
IR camera, USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Audio Input
Microphone
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Silver, black head
53.94 cm x 21.6 cm x 53.07 cm
6.5 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
Carbon Footprint
260 kg carbon emissions
TUV GS, VCCI, BSMI, GS, NOM, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, KC, CECP, CEL, EAC, CEL Grade 2, SEPA, BIS, low halogen, DisplayPort 1.2, Ukraine, Mercury-free, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, WW application, TUV-GS, Arsenic-free
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
Silver, black head
53.94 cm x 21.6 cm x 53.07 cm - with stand
6.5 kg
Audio Input
Microphone
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 upstream , USB (Type B) , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), volume control, detachable stand, VESA interface support, arsenic free, mercury free, microphone mute control
1 x DisplayPort 1.2 cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-A to USB-B cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
16 kWh/1000h
Power Consumption (Typical)
28 Watt
Power Consumption (Max)
50 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 21.6 cm - height: 53.07 cm - weight: 6.5 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 35.56 cm - weight: 3.9 kg
Shipping Width
59.6 cm
Shipping Depth
22.5 cm
Shipping Height
41.1 cm
Shipping Weight
10.4 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
162
Logistics (kg CO2e)
3
Use (kg CO2e)
76
EOL (kg CO2e)
5
Total Carbon w/o Use Phase (kg CO2e)
250
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Brand: HP
