HP offers a variety of optional products (each sold separately) designed to complement our monitors and enhance the overall computing experience. The super-compact HP USB Graphics Adapter enables connection of up to six simultaneous displays to help you boost productivity and multi-task across several open applications. Use one Adapter to bridge between a notebook or desktop PC and second monitor or use multiple Adapters to connect several displays to each other. Supports resolutions up to 1920 x 1080 (widescreen) or 1600 x 1200 (traditional).
Office flexibility
View large spreadsheets across two screens or multitask without overlapping windows. -
On the road flexibility
Enable multiple screen presentations from one PC. -
Graphics houses flexibility
Use a second display for palettes or tools or a panoramic view of large documents. -
Editing flexibility
Edit documents on one screen and reference data on another; compare multiple documents simultaneously.
- HP - external video adapter
- External video adapter
- Bus Type
- USB
- Max Resolution
- 1920 x 1080
- Interfaces Details
- DVI-I , VGA - with adapter
- 8.4 cm x 5.4 cm x 1.8 cm
- 1-year warranty
- Designed For
- EliteBook Folio 1020 G1; EliteDesk 700 G1, 705 G3, 705 G4, 800 G2, 800 G4; EliteOne 705 G2, 800 G1, 800 G2, 800 G3; Mini 100; Mobile Thin Client 2533; Pavilion Elite m9165; ProDesk 400 G3, 400 G4, 400 G5, 490 G3, 600 G2, 600 G3, 600 G4; ProOne 400 G2, 400 G3, 600 G2, 600 G3; Spectre Pro x360 G1
- Bus Type
- USB
- Max Resolution
- 1920 x 1080
- Cables Included
- 1 x USB cable , 1 x DVI-VGA adapter
- EN55022, ICES-003, EN55024, FCC Part 15 B, RoHS
- 8.4 cm
- 5.4 cm
- 1.8 cm
- 231 g
- Limited warranty - 1 year
- 10 °C
- 40 °C
- Designed For
- HP EliteBook Folio 1020 G1 , HP EliteDesk 700 G1, 705 G3, 705 G4, 800 G2, 800 G4 , HP EliteOne 705 G2, 800 G1 Retail System, 800 G2, 800 G3 , HP Mini 100e Education Edition , HP Pavilion Elite m9135.ch, Elite m9140.ch, Elite m9160.ch-a, Elite m9161.sc, Elite m9165.uk-a, Elite m9180.fr, Elite m9180.it, Elite m9180.nl, Elite m9180f, Elite m9190.nl, Elite m9380.it , HP ProDesk 400 G3, 400 G4, 400 G5, 490 G3, 600 G2, 600 G3, 600 G4 , HP ProOne 400 G2, 400 G3, 600 G2, 600 G3 , HP Spectre Pro x360 G1 , HP Compaq 6510b , HP Compaq Mobile Thin Client 2533t, 6720t
