HP Ultrium  448 External Drive
Quicklinx: 48BMWS00 Mfr#: DW017B
The HP StorageWorks Ultrium 448 Tape Drive based on second generation LTO technology is positioned as the affordable tape backup solution providing mid-range customers with the best mix of features and value today and in the future for protecting data on their mid-range SCSI and Serial Attached SCSI (SAS)-based servers. The Ultrium 448 Tape Drive delivers a compressed storage capacity of 400 GB per data cartridge using LTO 2 media. By doubling the capacity of the current half-height HP Ultrium 232 Tape Drive, customers will now use fewer data cartridges to meet their storage needs, reducing their IT costs and increasing their return on investment. Capable of backing up half a Terabyte of storage in 2.5 hours, the fast performance of the Ultrium 448 is enhanced by HP's exclusive dynamic data rate matching feature which can match the throughput of the host. The Ultrium 448 Tape Drive is fully read and write compatible with all first and second-generation Ultrium drives and media.
HPE StorageWorks Ultrium 448 - tape drive - LTO Ultrium - SCSI
Tape drive
Recording Standard
LTO Ultrium 2
Enclosure Type
External
Interface Type
SCSI LVD
20.8 cm x 29.2 cm x 7 cm
4.7 kg
Carbonite
Storage Removable
LTO Ultrium
Storage Removable Capacity
200 GB (native) / 400 GB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 2
Data Transfer Rate (native)
24 MBps (84.4 GBph)
Data Transfer Rate (compressed)
48 MBps (169 GBph)
IBM AIX, SunSoft Solaris, HP-UX, Novell NetWare, Red Hat Linux, Microsoft Windows, UnitedLinux
Microsoft Certification
Compatible with Windows 7
3-year warranty
ProLiant DL360 G5 Base, DL360 G5 Entry, DL360 G5 Performance, DL380 G4, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL385, DL385 G2 Base, ML115 G5
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 2
Enclosure Type
External
Interface Type
SCSI LVD
Built-in Devices
Led panel
Enclosure Colour
Carbonite
20.8 cm
29.2 cm
7 cm
4.7 kg
Storage Removable
LTO Ultrium
Ultrium 2
Recording Standard
Ultrium 2
24 MBps (84.4 GBph)
48 MBps (169 GBph)
Average Seek / Access Time
64 sec
Buffer Size
64 MB
1 x Ultra160 SCSI LVD - 68 pin HD D-Sub (HD-68)
Media Included Qty
1
1 x SCSI cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15
Power supply
33 watt
Software Included
Drivers & Utilities, HP OpenView Storage Data Protector, HP StorageWorks Library and Tape Tools
Limited warranty - parts - 3 years - response time: next day
10 °C
20 - 80%
HPE ProLiant DL360 G5 Base, DL360 G5 Entry, DL360 G5 Performance, DL380 G4, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL385, DL385 G2 Base, ML115 G5
48BM HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
