Tackle your hybrid local and virtual computing workloads with the HP t640 Thin Client. Help keep your data and device safe across your workflows with built-in security features. Choose the right fit for your specific users and environment with a range of subsystem options.
Optimize for your environment
Balance the load on remote resources with the HP t640 Thin Client that easily integrates into your virtualized computing or a hybrid cloud computing environment. -
Built for the modern workspace
Create a more modern workspace by configuring your HP t640 Thin Client to work with a USB-C docking display. -
Proactive protection controls
Deter unauthorized updates with an embedded operating system that protects flash memory. Customize user settings and permissions to monitor and control incoming and outgoing data. -
Do not disturb
Create a working environment focused on productivity with the fanless t640 Thin Client equipped with modern solid-state drives for near silent operation.
- HP t640 - SFF Ryzen Embedded R1505G 2.4 GHz - 8 GB - flash 128 GB
- Thin client - SFF
- Localisation
- Processor
- 1 x AMD Ryzen Embedded R1505G / 2.4 GHz (, up to 3.3 GHz, (Dual-Core)
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Hard Drive
- Flash 128 GB - SATA - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon Vega 3
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise for Thin Clients 64-bit Edition
- 3.5 cm x 19.6 cm x 19.6 cm
- 994.5 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- SFF
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD Ryzen Embedded R1505G
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 128 GB
- Interface Type
- SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon Vega 3
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 3
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x M.2 Card
- 3 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 2 x USB 2.0 , 3 x USB 3.1 Gen 1 , USB 3.1 Gen 2 , 1 x USB-C 3.1 Gen 2 , 1 x audio line-out/line-in
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, UL, BSMI, GS, CB, CCC, EMC, RoHS, ICES Class B, WEEE, EN 60601-1-2, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B, SEPA, HP GSE, EN, CNS
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise for Thin Clients 64-bit Edition English
Sustainability Information
- ENERGY STAR Certified
- 3.5 cm
- 19.6 cm
- 19.6 cm
- 994.5 g
- Shipping Weight
- 2.878 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £24.71 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £48.26 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £36.49 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.69 |
Keyboards and Mice (1)
HP 128 Wired Mouse | In Stock | £8.31 |
Other bundles (6)
HPE DisplayPort To VGA Adapter | In Stock | £12.06 |
HPE DisplayPort to VGA Adapter | In Stock | £13.12 |
HP USB-C TO RJ45 Adapter | In Stock | £185.96 |
HP 65W USB-C LC Power Adapter | In Stock | £14.85 |
HP USB-C LC Power Adapter - 65 Watt | In Stock | £14.85 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £87.51 |
