Easy to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
Carry and store with your device
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
 - HP USB-C LC - power adapter - 65 Watt
 - Power adapter - external
- Localisation
 - English / United Kingdom
- Input Voltage
 - AC
- Power Capacity
 - 65 Watt
- Designed For
 - Pro c640 G2 Chromebook; ProBook 635 Aero G7 Notebook
- Localisation
- Input Voltage
 - AC
- Power Capacity
 - 65 Watt
- Designed For
 - HP Pro c640 G2 Chromebook , HP ProBook 635 Aero G7 Notebook
