The HP StorageWorks Ultrium 448 tape drive represents HP's second generation of half-height LTO tape drive technology. As the highest capacity, highest performance half-height drive in the StorageWorks family, the Ultrium 448 delivers a compressed storage capacity of 400 GB per data cartridge, using LTO 2 media. The Ultrium 448 Tape Drive is fully read and write compatible with all first and second-generation Ultrium drives and media. These features combined with low pricing make the Ultrium 448 the ideal direct-attach and network backup solution for entry-level and midrange servers where capacity and low cost of ownership are critical.
- HPE StorageWorks Ultrium 448 - tape drive - LTO Ultrium - SAS
- Tape drive
- Recording Standard
- LTO Ultrium 2
- Enclosure Type
- Internal
- Interface Type
- SAS
- 14.5 cm x 20.6 cm x 4.1 cm
- 1.5 kg
- Carbonite
- Storage Removable
- LTO Ultrium - 5.25" x 1/2H
- Storage Removable Capacity
- 200 GB (native) / 400 GB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 2
- Data Transfer Rate (native)
- 24 MBps (86 GBph)
- Data Transfer Rate (compressed)
- 48 MBps (173 GBph)
- OS Required
- IBM AIX, SunSoft Solaris, HP-UX, Novell NetWare, Red Hat Linux, Microsoft Windows, UnitedLinux
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Designed For
- Workstation xw4600, xw6600, xw8600, xw9400, z400, z600, z800; ProLiant DL580 G5, ML110 G4, ML110 G5, ML115, ML115 G1, ML115 G5, ML150 G3, ML150 G5, ML150 G6, ML310 G3, ML310 G4, ML310 G5, ML310 G5p, ML330 G6, ML350 G4, ML350 G5, ML350 G6, ML370 G4, ML370 G5, ML370 G6, ML570 G3, ML570 G4
- Tape drive - LTO Ultrium
- LTO Ultrium 2
- Enclosure Type
- Internal
- Interface Type
- SAS
- Built-in Devices
- Led panel
- Enclosure Colour
- Carbonite
- 14.5 cm
- 20.6 cm
- 4.1 cm
- 1.5 kg
Storage Removable
- Capacity
- Ultrium 2
- Ultrium 2
- 24 MBps (86 GBph)
- Average Seek / Access Time
- 64 sec
- Buffer Size
- 64 MB
- 1 x SAS
- Media Included Qty
- 5
- Cables Included
- 1 x SAS cable
- MTBF
- 250,000 hour(s)
- TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15
- Software Included
- Drivers & Utilities, HP StorageWorks Library and Tape Tools, HP StorageWorks Data Protector Express Single Server
- OS Required
- Limited warranty - parts - 3 years - response time: next day
- 10 °C
- 40 °C
- 20 - 80%
- Designed For
- HP Workstation xw4600, xw6600, xw8600, xw9400, z400, z600, z800 , HPE ProLiant DL580 G5, DL580 G5 Base, DL580 G5 High Performance, ML110 G4, ML110 G5, ML110 G5 1TB Storage Server, ML110 G5 2TB Storage Server, ML110 G5 320GB Storage Server, ML110 G5 584GB Storage Server, ML115, ML115 G1, ML115 G5, ML150 G3, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML150 G5 Special Server, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G3, ML310 G4, ML310 G4 1TB Storage Server, ML310 G4 2TB Storage Server, ML310 G4 3TB Storage Server, ML310 G4 584 GB SAS Storage, ML310 G4 640 GB Storage Server, ML310 G5, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G4, ML350 G5, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G4, ML370 G4 High Performance, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML570 G3, ML570 G3 High Performance, ML570 G4, ML570 G4 High Performance
