HP Storageworks 70 Modular Smart
Quicklinx: 4H2GWS00 Mfr#: 418800-B21
Manage your small and midrange business growing storage needs by deploying this low cost, flexible tiered storage system with up to 7.5TB SAS or 6.2TB SATA storage per enclosure. For small businesses, MSA70 is a stepping stone to simplify capacity expansion of HP ProLiant or HP Integrity server environments to external storage without having to make the full move to SAN or NAS, allowing you to buy what is needed today and purchase additional capacity as data storage needs grow. MSA70 also supports attach to the MSA2324fc Array. Add a second I/O Module to transition from single domain to dual domain for higher levels of redundancy and reliability reducing or eliminating single points of failure within your storage network. On ProLiant servers Dual Domain support is available for the SA P800 attached to a MSA70. On Integrity servers for HP-UX and OVMS environments the HP SC44Ge HBA adds support for Multi-Initiator JBOD Clusters.
HPE StorageWorks Modular Smart Array 70 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
7.5 TB
0 (installed) / 25 (max)
Supported Drives
SATA-300 / SAS-2
Built-in Devices
Led panel
Hard Drive
0 HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
44.8 cm x 59 cm x 8.8 cm
15.9 kg
3-year warranty
ProLiant DL120 G6, DL120 G7, DL160 G6, DL165 G5, DL165 G6, DL170h G6, DL180 G5, DL180 G6, DL185 G5, DL320 G5p, DL320 G6, DL360 G6, DL360 G7, DL370 G6, DL380 G6, DL385 G5, DL385 G5p, DL385 G6, DL385 G7, DL580 G5, DL580 G7, DL585 G6, DL585 G7, DL785 G5, DL785 G6, ML310 G5, ML330 G6, ML350 G6, ML370 G6
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
Built-in Devices
Led panel
0
Supported Devices / Modules Qty
25
Supported Drives
SATA-300 / SAS-2
Storage
7.5 TB
CPU
No CPU
Hard Drive
HDD - hot-swap
0
Expansion Bays
25 (total) / 25 (free) x hot-swap - 2.5" SFF
1 x SAS (input) - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) , 1 x SAS (output) - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
1 x SAS cable - 50 cm
Rack Mounting Kit
Included
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
44.8 cm
59 cm
8.8 cm
15.9 kg
Limited warranty - parts - 3 years
10 °C
35 °C
10 - 90%
HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL160 G6, DL165 G5 Special Server, DL165 G6, DL170h G6, DL180 G5 Special Server, DL180 G6, DL180 G6 Special Server, DL185 G5 Special Server, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL380 G5 Storage Server 2TB SATA Model, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML310 G5, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G5, ML370 G6, ML370 G6 Base, ML370 G6 Entry
