HP SCANJET PROFESSIONAL 3000 sheet feed scanner
HP Scanjet Professional 3000 Sheet-feed Scanner
Quicklinx: 772LWS00 Mfr#: L2723A#B19
Scan business documents from your desktop, using a fast, reliable, sheet-feed scanner. Scan two-sided documents at up to 20 pages per minute, using the 50-page automatic document feeder, and catch misfed pages with ultrasonic double-feed detection.
Digitize documents with fast, two-sided scanning.
  • Scan up to 20 ppm/40 ipm at 300 dpi in black and white, grayscale and color.
  • Scan up to 50 pages at a time while tending to other projects--just press Scan and walk away.
  • Archive files with Nuance PaperPort, and convert scans into editable files with Nuance OmniPage.[1]
  • Scan and organize business cards using NewSoft Presto! BizCard Reader software.[1]
Easily convert your hard copies to digital files.
  • Scan with the touch of a button.
  • Integrates with leading content management applications using the TWAIN software driver.
  • Capture all the detail and fine print at up to 600 dpi scanning resolution.
  • Scan in different file formats--PDF, TIFF, JPEG, Microsoft Word--and save disk space with smaller file sizes.
Count on reliable document capture and HP support.
  • Reliably scan every page of your document, using ultrasonic double-feed detection.
  • Tackle a variety of paper types, thicknesses and sizes reliably.
  • Rely on this scanner to work hard for you every day with a duty cycle of up to 1000 pages per day.
  • Get a one-year limited warranty and the support and services of HP Total Care.
Save energy with Instant-on scanning technology Reduce clutter and waste--scan and share documents digitally Uses 50% less packaging than previous model
ENERGY STAR® Qualified
http://www.hp.com/ecosolutions
  • Digitise documents with fast, two-sided scanning
    Scan up to 20 ppm/40 ipm at 300 dpi in black and white, greyscale and colour.Scan up to 50 pages at a time while tending to other projects using the automatic document feeder.Count on ultrasonic double-feed detection to scan every page - just press scan and walk away.Organise, archive and share files with Nuance PaperPort, and convert scans into editable files with Nuance OmniPage.Scan and organise business cards and embossed cards, using NewSoft Presto! BizCard Reader software.
  • Easily convert your hard copies to digital files
    One-touch buttons make it easy to start scanning when you're ready.Easily scan from programmes and compatible applications already installed on your PC, using TWAIN software drivers.Capture all the detail and fine print – get sharp, clear, legible documents at up to 600 dpi scanning resolution.Scan in different file formats-PDF, TIFF, JPEG, Microsoft Word-and save disk space with smaller file sizes.
  • Count on reliable document capture and HP support
    Reliably scan every page of your document, using ultrasonic double-feed detection.Tackle a wide variety of paper types, thicknesses and sizes - business cards, A4-size documents and forms up to 34 inches/86 cm long.Rely on this scanner to work hard for you every day with a duty cycle of up to 1,000 pages per day.Get a one-year limited warranty including quick phone or online support from HP.Access the technology, services, solutions and support and services of HP Total Care.
HP ScanJet Professional 3000 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
215.9 x 863.6 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
215.9 mm x 863.6 mm
Supported Document Type
Plain paper, business card, plastic card, check, labels
Document Storage Capacity
50 sheets
Duty Cycle
1000 scans per day
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.6, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.5
Microsoft Certification
Compatible with Windows 7
28.6 cm x 15.3 cm x 16.2 cm
2.3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
215.9 x 863.6 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Control Panel Buttons Functions
Scan, cancel
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - black & white - A4 - 200 dpi , 20 ppm - colour - A4 - 200 dpi
TWAIN
Media Handling
Max Document Size
215.9 mm x 863.6 mm
50 sheets
Interfaces Details
USB 2.0
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
11.38 Watt
Software Included
Drivers & Utilities, Nuance PaperPort, Nuance OmniPage, Presto! BizCard SE
28.6 cm
15.3 cm
16.2 cm
2.3 kg
Shipping Width
36.8 cm
Shipping Depth
28.5 cm
Shipping Height
22 cm
Shipping Weight
4 kg
10 - 80%
