Scan documents on the spot, wherever you are--in the office, in the field or on the go--with the HP compact, portable scanner. Organize contracts, forms, receipts and business cards on your PC instead of on your desk or in your briefcase.
Digitize documents nearly anywhere and on the go.
- Capture documents on the spot--in the office, at your customer's site and even on the road.
- Carry and use the scanner almost anywhere--it's lightweight, portable and compact.
- Protect and store the scanner in the included sturdy carrying case.
- Power the mobile scanner via your PC's Hi-Speed USB 2.0 port--no batteries or AC adapter needed.
Easily scan and organize your digital information.
- Scan with the touch of a button or scan directly from the application you're working in.
- Scan in different file formats--PDF, TIFF, JPEG, Microsoft Word--and save disk space with smaller file sizes.
- Archive files with Nuance PaperPort, and convert scans into editable files with Nuance OmniPage.[1]
- Scan and organize business cards and embossed cards, using NewSoft Presto! BizCard Reader software.[1]
Quickly scan a variety of two-sided documents.
Save energy with Instant-on scanning technology Reduce clutter and waste--scan and share documents digitally Reduce packaging waste, contains innovative, reusable tote made from recycled plastic bottles
ENERGY STAR® Qualified
HP Scanjet Professional 1000 Mobile Scanner
http://www.hp.com/ecosolutions
- Scan a variety of paper sizes, from business cards to long forms.
- Scan at up to 5 ppm or two-sided in a single pass at up to 8 ipm, using the manual feed slot.
- Capture all the detail and fine print at up to 600 dpi scanning resolution.
Digitise documents anywhere and on the go
Capture documents on the spot: in the office, at your customer's site and even on the road.Carry and use the scanner almost anywhere as it's robust, lightweight, portable and compact.Protect and store the scanner in the sturdy carrying case (included).Power the mobile scanner via your PC's Hi-speed USB 2.0 port - no batteries or AC adapter needed. -
Easily scan and organise your digital information
Scan with the touch of a button; scan directly from the programme or application you're working in.Scan in different file formats: PDF, TIFF, JPEG, Microsoft Word, and save disk space on your hard drive with smaller file sizes.Organise, archive and share scanned documents and images, using Nuance PaperPort and convert scans into editable and shareable files with Nuance OmniPage.Scan and organise business cards and embossed cards, using NewSoft Presto! BizCard Reader software. -
Scan a variety of paper sizes, from business cards, notes, embossed cards, signatures and A4-size documents, to forms up to 14 inches/36 cm long.Scan at up to 5 ppm or two-sided in a single pass at up to 8 ipm, using the manual feed slot.Capture all the detail and fine print: get sharp, clear, legible documents at up to 600 dpi scanning resolution.
- HP ScanJet 1000 Professional Mobile Scanner - sheetfed scanner - desktop - USB 2.0
- Sheetfed scanner - desktop
- Interface Type
- USB 2.0
- Max Supported Document Size
- 216 x 864 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Size
- 216 mm x 864 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Manual
- Duty Cycle
- 100 scans per day
- System Requirements
- Microsoft Windows 2000 / XP, Microsoft Windows 7, Microsoft Windows Vista
- Microsoft Certification
- Certified for Windows Vista
- 29 cm x 5 cm x 7.5 cm
- 0.66 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 864 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- 600 dpi x 600 dpi
- Duty Cycle
- 100 scans per day
Media Handling
- Max Document Size
- 216 mm x 864 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 216 x 864 mm
- Manual
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- ENERGY STAR Certified
- OS Required
- 29 cm
- 5 cm
- 7.5 cm
- 0.66 kg
- Shipping Width
- 34.5 cm
- Shipping Depth
- 15.5 cm
- Shipping Height
- 8.7 cm
- Shipping Weight
- 1.2 kg
- 10 - 80%
