HP Scanjet Pro 3000 S2 Sheetfeed Scanner
Quicklinx: 8ZJTWS00 Mfr#: L2737A#B19
Turn the page on time-consuming, manual document handling. This intelligent scanner is easy to use and makes any office more efficient. Get clear, crisp digital documents every time – and cut your power consumption with this energy-efficient device.
  • Save time, skip manual steps, be more efficient and create one-click short cuts with HP Easy Scan
    Spend less time digitising documents and more time doing business.Accurately capture the right results with auto-scan mode, crop and colour detection.Work smarter with intuitive shortcuts and HP Easy Scan. Create PDF files with a single touch and easily plug right in to existing scanning platforms.Seamlessly add high-volume scanning to existing processes with HP TWAIN, ISIS, WIA, Linux and Mac drivers.
  • Avoid lost pages in scanned files
    Make missed pages a thing of the past. The HP Scanjet Pro 3000 s2 Sheet-feed Scanner individually feeds and auto-aligns each page.Quickly scan files and get crisp, clean results again and again with a scanner that works hard for your business.Whether close at hand, or centrally situated, with its compact design the HP Scanjet Pro 3000 s2 Sheet-feed Scanner fits into even the busiest offices.Scan at up to 600dpi and rely on a device that just won't quit – scan up to 1,000 pages per day.
  • Start fast and keep going
    Waste less paper and ink, by scanning, storing and sharing documents digitally. And you cut down on clutter.Manage costs with an ENERGY STAR qualified scanner. Reduce energy use without slowing down, and start scanning quickly from low-power mode.Cut your environmental impact with a scanner that's fully RoHS-compliant and free of mercury, lead and other hazardous materials.And you enjoy complete peace of mind with a one-year limited warranty, including quick phone or online support from HP.
HP Scanjet Pro 3000 s2 - sheetfed scanner - desktop - USB 2.0
Sheetfed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
215.9 x 864 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
215.9 mm x 864 mm
Automatic Duplexing
Document Feeder Type
Automatic
Duty Cycle
1000 scans per day
Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
28.5 cm x 16.1 cm x 16.4 cm
2.3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
215.9 x 864 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Control Panel Buttons Functions
Scan, cancel
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - 300 dpi (front) / 300 dpi (back) , 40 ipm - duplex - 300 dpi (front) / 300 dpi (back)
Scanner Features
Ultrasonic Multi Feed Detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 864 mm
Supported Document Size Details
ADF - up to 215.9 x 864 mm
Automatic
USB 2.0
1 x USB cable
GOST, CISPR 24, EN55022, SASO, EN55024, CISPR 22, EMC, RoHS, IEC 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 61000-3-2:2006, EN 61000-3-3:2008, EN 60950-1:2006
ENERGY STAR Certified
Power Consumption Operational (Standby)
11.6 Watt (5.9 Watt)
Software Included
Readiris Pro 14, HP Easy Scan, Nuance PaperPort 14, Cardiris Pro 5
System Requirements Details
Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 177 MB , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 177 MB
28.5 cm
16.1 cm
16.4 cm
2.3 kg
Shipping Width
38 cm
Shipping Depth
28.5 cm
Shipping Height
21.6 cm
Shipping Weight
4 kg
10 °C
35 °C
15 - 80%
