Enhance productivity for routine scanning with a compact HP ScanJet Pro. Automate workflow with fast, two-sided scanning, a 50-page ADF, 1,500-page daily duty cycle, and one-button shortcuts. You can even quickly capture and edit text from documents.
                Boost productivity with fast, versatile scanningProduce up to 40 images per minute with two-sided scanning and a 50-page automatic document feeder.Scan pages up to 21.6 cm x 309.9 cm (8.5 x 122 inches) through the ADF, and use the flatbed for bulky media.Don't wait for warm-up – Instant-on Technology lets you begin scanning quickly.Free up space for work. This HP ScanJet is small and slim – a modern design perfect for the desktop.
                Automate and streamline your workflowStreamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.Define scan profiles for common document types and scan to multiple destinations with HP Scan software.Quickly share or archive scans directly to popular cloud destinations with HP Scan software.Scan directly into applications without opening another program with HP's full-featured TWAIN driver.
                Sharp images and powerful editing toolsAccurately capture text from documents for easy editing with HP Scan and I.R.I.S. Readiris Pro OCR software.Get sharp, true-to-life scans of documents, graphics, and photos with up to 1200 dpi resolution.Easily edit and organise documents and photos with a full suite of feature-rich software.Auto-imaging features in the included HP Scan software let you Enhance images and delete blank pages.
- HP Scanjet Pro 2500 f1 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CMOS / CIS
- Light Source
- LED
- Max Supported Document Size
- 216 x 3100 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 20 ppm (mono) / 20 ppm (colour)
- Max Document Size
- 216 mm x 3100 mm
- Automatic Duplexing
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 1500 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 45.1 cm x 35.1 cm x 12.2 cm
- 4.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 216 x 3100 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- Scan Mode
- Single-pass
- CMOS / CIS
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 20 ppm
- Max Document Scan Speed Colour
- 20 ppm
- Control Panel Buttons Functions
- Scan, cancel, duplex
- Duty Cycle
- Scanner Speed Details
- 20 ppm - 300 dpi , 40 ipm - duplex - 300 dpi (front) / 300 dpi (back)
- TWAIN, WIA
Media Handling
- Max Document Size
- 216 mm x 3100 mm
- Supported Document Size Details
- ADF - up to 216 x 3100 mm , Flatbed - up to 216 x 297 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- C-Tick, BSMI, CISPR 24, cUL, EN 61000-3-2, EN55022, ICES-003, SASO, EN 61000-3-3, CISPR 22, CCC, EMC, RoHS, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, KCC, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1 Second Edition, KN22, EAC, TER, PVOC, CoC
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Stand by
- 4.73 Watt
- Power Consumption Sleep
- 1.68 Watt
- Software Included
- Readiris Pro, Cardiris, ArcSoft PhotoStudio, Nuance PaperPort, HP Scan, HP Scanner Tools Utility
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - 2 GHz - RAM 2 GB - HD 170 MB , MacOS X 10.9/10.10 - RAM 1 GB
- 45.1 cm
- 35.1 cm
- 12.2 cm
- 4.3 kg
- Shipping Width
- 54.8 cm
- Shipping Depth
- 46.5 cm
- Shipping Height
- 19.4 cm
- Shipping Weight
- 6.1 kg
- Limited warranty - 1 year
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
