Product
Brand
HP ScanJet G4050
HP Scanjet G4050 Fotoscanner
HP ScanJet G4050
Quicklinx: 4DCRWS00 Mfr#: L1957A#B19
Scan multiple photos, slides, film and negatives and get superior colour accuracy with 6-colour, 96-bit scanning – exclusive to HP. Capture every detail with 4800 x 9600-dpi hardware resolution. Get infrared-based dust /scratch removal too.
HP ScanJet G4050 Photo Scanner - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Max Supported Document Size
216 x 311 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 96-bit colour
Optical Resolution
4800 dpi x 9600 dpi
Max Document Size
216 mm x 311 mm
Supported Document Type
Plain paper, slides, bulk objects (such as books, magazines and other bound materials), film
Document Feeder Type
Manual
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.4 or later
Microsoft Certification
Certified for Windows Vista
30.3 cm x 50.8 cm x 10.8 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 311 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
96-bit colour
Optical Resolution
4800 dpi x 9600 dpi
Scan Element Type
CCD
Control Panel Buttons Functions
Scan, copy, Scan film, Scan-to-PDF
Scanner Speed Details
29 sec/scan - photo - colour - 10x15cm , 25 sec/scan - OCR - A4 , 35 sec/scan - film (positives) - 35mm , 45 sec/scan - film (negatives) - 35mm , 8.5 sec/scan - preview
TWAIN
Media Handling
Max Document Size
216 mm x 311 mm
Manual
USB 2.0
Transparency adaptor, film holder
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
UL, BSMI, GOST, cUL, CCC, MIC, FCC, IEC 60950-1, ACA
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
25 Watt
Software Included
Drivers & Utilities
System Requirements Details
MacOS X 10.3.9 or later - PowerPC G3 RAM 128 MB - HD 250 MB (USB) , Windows 2000/XP - Pentium II - 233 MHz - RAM 128 MB - HD 500 MB (USB)
30.3 cm
50.8 cm
10.8 cm
5.3 kg
10 °C
35 °C
0 - 90%
