HP SCANJET G3110 USB2 A4 FLATBED
HP Scanjet G3110 Fotoscanner
Quicklinx: 73F5WS00 Mfr#: L2698A#B19
Enjoy easy scanning at the touch of a button with this stylish, affordable scanner. Get great results from your photos, slides and negatives, then enhance or restore them using intuitive software. Scan and manage documents for easy archiving too.
  • Get more from your photos with high-quality scanning and easy restoration
    Turn your photos into high-quality, easy-to-share digital images with 4800 x 9600 dpi resolution and 48-bit colour. Remove red-eye, improve contrast, restore faded colour and remove dust and scratches using included software.
  • Scan multiple photos, slides, negatives or even 3-D objects and save to separate files
    Scan multiple originals – up to four 35 mm slides, five negatives or three 10 x 15 cm photos – at once and save as separate files. Get impressive results from open books, framed pictures and even 3-D objects such as jewellery or collectables.
  • Turn paperwork into editable documents and easy-to-archive digital files
    Turn important documents into easy-to-archive PDF files or convert them into editable text using the Optical Character Recognition (OCR) software. Enjoy the speed and convenience of one-touch Copy and Scan-to-Email buttons too.
HP ScanJet G3110 Photo Scanner - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Max Supported Document Size
220 x 300 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
4800 dpi x 9600 dpi
Max Document Size
220 mm x 300 mm
Supported Document Type
Transparencies, plain paper, slides
Document Feeder Type
Manual
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Apple MacOS X 10.4.11
Microsoft Certification
Certified for Windows Vista
30.5 cm x 45.5 cm x 7 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
220 x 300 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
4800 dpi x 9600 dpi
CCD
Control Panel Buttons Functions
Scan, copy, Scan-to-Email, Scan-to-PDF
Scanner Speed Details
28 sec/scan - photo - colour - 10x15cm , 28 sec/scan - OCR - A4 , 26 sec/scan - film - 35mm , 21 sec/scan - photo - colour - 10x15cm , 28 sec/scan - A4 , 11 sec/scan - preview
TWAIN
Media Handling
Max Document Size
220 mm x 300 mm
Manual
USB 2.0 - Type B
Transparency adaptor
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
TUV GS, BSMI, GOST, cUL, CB, CCC, MIC, FCC, UL 60950-1, IEC 60950-1, EN 60950-1
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
15 Watt
Software Included
HP Photosmart Essential
System Requirements Details
Windows 2000/XP - 500 MHz - RAM 128 MB - HD 450 MB (USB) , Windows Vista - 800 MHz - RAM 512 MB - HD 450 MB (USB)
30.5 cm
45.5 cm
7 cm
2.9 kg
Shipping Width
54.2 cm
Shipping Depth
44.3 cm
Shipping Height
13.1 cm
Shipping Weight
3.7 kg
10 °C
35 °C
0 - 90%
