HP ScanJet Enterprise Flow 5000 s4 Sheet-feed Scanner - document scanner
Quicklinx: CJ2WWS00 Mfr#: L2755A#B19
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 215.9 x 3098.8 mm
Interface: USB 2.0, USB 3.0
Compatibility: PC
Hurry, only 2 left in stock!
£439.67 ex VAT
£527.60 inc VAT
Give your office powerful scan speed and accuracy. Built-in software and an 80-page automatic document feeder help you save time. Scan at up to 50 ppm/100 ipm. Recommended for 6,000 pages per day.
Fast, smooth scanning – even unattended
Capture entire documents with one-pass duplex scanning up to 50 ppm/100 ipm.
Peak workflow performance. Smarter scanning.
Identify new devices and gain insight into scanning with HP Web Jetadmin remote discovery and monitoring.
Professional-grade scanning that helps save time
Save time and simplify complex scan jobs with HP Smart Document Scan Software.
  • Fast, smooth scanning – even unattended
    Capture entire documents with one-pass duplex scanning up to 50 ppm/100 ipm.Free up space for work. This HP ScanJet is small and slim – a modern design perfect for the desktop.Capture a wide range of documents – even stacks of mixed media sizes and types – with HP EveryPage.Load up to 80 pages into the automatic document feeder for fast, unattended scanning.
  • Peak workflow performance
    Identify new devices and gain insight into scanning with HP Web Jetadmin remote discovery and monitoring.Simplify the way you scan A3-size documents – no need for a carrier sheet.Scan images directly into applications with included and full-featured TWAIN and ISIS .Easily transfer scans into editable text, encrypted PDF files, and more file types, using built-in OCR.
  • Professional-grade scanning that helps save time
    Save time and simplify complex scan jobs with HP Smart Document Scan Software.Create one-button scan settings for recurring tasks, and make selections using the LCD control panel.Scan directly to mobile devices with the HP JetAdvantage Capture App, using the optional wireless accessory, and then edit and save files.Capture and organise documents, business cards, and other file types with feature-rich software.
HP ScanJet Enterprise Flow 5000 s4 Sheet-feed Scanner - document scanner - desktop - USB 3.0, USB 2.0
Document scanner - desktop
Interface Type
USB 3.0, USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Additional Functions
Email
Max Supported Document Size
215.9 x 3098.8 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
55 ppm (mono) / 45 ppm (colour)
Max Document Size
215.9 mm x 3098.8 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0, USB 2.0
Email
215.9 x 3098.8 mm
Scanner
Input Type
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
55 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
55 ppm - black & white - 300 dpi , 45 ppm - colour - 300 dpi , 110 ipm - duplex - black & white - 300 dpi , 90 ipm - duplex - colour - 300 dpi , 5.18 sec/scan - photo - colour - 10x15cm - 200 dpi , 4.98 sec/scan - photo - colour - 10x15cm - 150 dpi , 6.63 sec/scan - colour - A4 - 300 dpi
Scanner Features
Ultrasonic Multi Feed Detection, HP EveryPage
Scan File Formats
BMP, JPEG, PNG, TIFF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
Supported Document Size Details
ADF - up to 215.9 x 3098.8 mm
Automatic
80 sheets
USB 3.0 , USB 2.0
ENERGY STAR Certified
Software Included
Readiris Pro, Cardiris, Nuance PaperPort, HP Smart Document Scan Software, HP Scanner Tools Utility
Shipping Width
39.7 cm
Shipping Depth
30.3 cm
Shipping Height
24.8 cm
Shipping Weight
5.4 kg
Interface: USB 2.0
Interface: USB 3.0
Compatibility: PC
Brand: HP
Price Range Ex VAT: 300 - 500
