Manage all your office scanning processes with this fast, easy-to-use business scanner. Automatically capture stacks of single or double-sided documents and streamline common tasks such as saving, filing and organising scanned images.
Fast document scanning for your everyday needs
Capture documents in black, greyscale or colour at up to 25 ppm/50 ipm with this easy to use simplex/duplex scanner. Experience reliable unattended operation with 50-page automatic document feeder and handle volumes of up to 1,500 pages a day. -
Streamline everyday scanning tasks using programmable, easy-to-access scan profiles
Streamline processes using HP Smart Document Scan Software. Create customised scan profiles, preview and edit scanned images, save in a wide range of file formats including PDF and Microsoft Word, and send directly to email, folder or application. -
Get started with document management today
Create a document management solution out of the box with ScanSoft PaperPort , or integrate into an existing system using ISIS , TWAIN and WIA drivers. Convert scans into editable text with IRIS Readiris Pro OCR software.
- HP ScanJet 5000 - sheetfed scanner - desktop - USB 2.0
- Sheetfed scanner - desktop
- Interface Type
- USB 2.0
- Max Supported Document Size
- 216 x 864 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Size
- 216 mm x 864 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 2000 scans per day
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista
- Microsoft Certification
- Certified for Windows Vista
- 32 cm x 28 cm x 24.6 cm
- 7.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 216 x 864 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- 600 dpi x 600 dpi
- Duty Cycle
- TWAIN
Media Handling
- Max Document Size
- 216 mm x 864 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 216 x 864 mm
- Automatic
- 50 sheets
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- ENERGY STAR Certified
- Power Consumption Operational (Standby)
- 40 Watt
- OS Required
- 32 cm
- 28 cm
- 24.6 cm
- 7.2 kg
- Shipping Width
- 49.6 cm
- Shipping Depth
- 40 cm
- Shipping Height
- 37.5 cm
- Shipping Weight
- 10.2 kg
- Limited warranty - express exchange - 1 year - carry-in
- 10 °C
- 35 °C
- 15 - 80%
