Protect your data and investment with the ProBook, designed to deliver impressive performance and reliability. Take on your workday with the budget-friendly HP ProBook 455. Ideal for professionals in corporate settings or small to medium businesses, wanting an affordable combination of innovation, essential security and multimedia capabilities.
Progressive style
Work confidently on the 15.6-inch diagonal HP ProBook 455, that is designed with an aluminum reinforced keyboard deck and an improved construction.
Affordable performance
Enjoy the robust performance of cost-effective and energy-efficient processor.
Protect your work
Help keep sensitive data secure with comprehensive security features.
Immersive experience
Enjoy the rich user experience of the HP ProBook 455 with long battery life and features, designed to create a stunning visual and audio experience with HP Audio Boost, noise cancellation, etc.
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 Pro on the thin, light, HP ProBook 455. -
Tested to go the distance
Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing. -
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Cancellation Software. -
Give your speakers a boost
Help make good speakers sound great with the HP Audio Boost. -
Help secure critical data
With TPM 2.0 embedded security, your critical data has protection with hardware-based encryption keys. -
Protect against minor spills
Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
- HP ProBook 455 G4 Notebook - 15.6" - AMD A10 - 9600P - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD A10 9600P / 2.4 GHz, up to 3.3 GHz / 2 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" WLED 1366 x 768 / HD
- Graphics
- AMD Radeon R5
- Input Device
- ClickPad
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 8 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 38.2 cm x 26.3 cm x 2.44 cm
- 2.19 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 1866 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R5
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Low light enhancement
- Sound
- Stereo speakers, two microphones
- High Definition Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP 2
- Miracast, Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.0 , 2 x USB 2.0 , HDMI , VGA , LAN , Headphone/microphone combo jack , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Password Manager, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart
- Case Material
- Brushed aluminium
- Security
- HP 3D DriveGuard, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
- Theft/Intrusion Protection
- Included Accessories
- Power adapter, HP Basic Carrying Case
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 2.19 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £22.69 |
HP 65W Smart AC Adapter | In Stock | £18.54 |
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £135.29 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £250.40 |
Other bundles (4)
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HP USB Travel Mouse | In Stock | £10.58 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
