Provide optimal power and help offset power fluctuations to your HP notebook with a HP 90W Smart AC Adapter. Now available with a new right-angled (90°) connector that reduces cable stress and an optional 4.5mm to 7.4mm conversion dongle. As a replacement or back-up adapter, be prepared with the right connection.
                Controlled and efficient flowOperate with confidence with optimal performance using smart-pin technology and reduce the risk of power surges, while drawing only minimal power as needed.
                Connection for today and yesterdayConnection versatility with a specially designed dongle allowing for simple conversion from the new standard 4.5mm connector to HP predecessor notebooks with 7.4mm connectors.
                The perfect right turnTight access made convenient – the new right-angled (90°) 4.5mm connector allows for connecting in limited spaces and reduces cord bending providing better cable management and longevity.
- HP Smart AC Adapter - power adapter - 90 Watt
- Power adapter - external
- 370 g
- Localisation
- English / United Kingdom
- Output Voltage
- 19 V
- Power Capacity
- 90 Watt
- Included Accessories
- 4.5mm to 7.4mm power DC dongle
- 12.7 cm x 5 cm x 2.9 cm
- Designed For
- HP 340 G5 Notebook, 348 G5 Notebook; EliteBook Folio 1020 G1, 1040 G2; ProBook 445r G6 Notebook, 455r G6 Notebook, 640 G5 Notebook, 650 G5 Notebook
- Localisation
- Output Voltage
- 19 V
- Power Capacity
- 90 Watt
- Cables Included
- Power cable
- Over voltage protection
- CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
- 0 °C
- 40 °C
- 20 - 80%
- 12.7 cm
- 5 cm
- 2.9 cm
- 370 g
- Shipping Weight
- 0.7 kg
- Designed For
- HP 340 G5 Notebook, 348 G5 Notebook , HP EliteBook Folio 1020 G1, 1040 G2 , HP ProBook 445r G6 Notebook, 455r G6 Notebook, 640 G5 Notebook, 650 G5 Notebook
