HP ProBook 455 G4 - 15.6" - A series A10-9600P - 4 GB RAM - 500 GB HDD with HP Basic Carrying Case
Quicklinx: CK8DWS00 Mfr#: Y8A72EA#ABU
  • IEEE 802.11n
Protect your data and investment with the ProBook, designed to deliver impressive performance and reliability. Take on your workday with the budget-friendly HP ProBook 455. Ideal for professionals in corporate settings or small to medium businesses, wanting an affordable combination of innovation, essential security and multimedia capabilities.
Progressive style
Work confidently on the 15.6-inch diagonal HP ProBook 455, that is designed with an aluminum reinforced keyboard deck and an improved construction.
Affordable performance
Enjoy the robust performance of cost-effective and energy-efficient processor.
Protect your work
Help keep sensitive data secure with comprehensive security features.
Immersive experience
Enjoy the rich user experience of the HP ProBook 455 with long battery life and features, designed to create a stunning visual and audio experience with HP Audio Boost, noise cancellation, etc.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the thin, light, HP ProBook 455.
  • Tested to go the distance
    Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
  • Cut out the chatter
    Help suppress ambient noise including keyboard clicks with HP Noise Cancellation Software.
  • Give your speakers a boost
    Help make good speakers sound great with the HP Audio Boost.
  • Help secure critical data
    With TPM 2.0 embedded security, your critical data has protection with hardware-based encryption keys.
  • Protect against minor spills
    Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
HP ProBook 455 G4 Notebook - 15.6" - AMD A10 - 9600P - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD A10 9600P / 2.4 GHz, up to 3.3 GHz / 2 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" WLED 1366 x 768 / HD
Graphics
AMD Radeon R5
Input Device
ClickPad
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 8 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
38.2 cm x 26.3 cm x 2.44 cm
2.19 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
1866 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM - tray
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
AMD Radeon R5
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Low light enhancement
Sound
Stereo speakers, two microphones
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Numeric Keypad
Spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
48 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB 3.0 , 2 x USB 2.0 , HDMI , VGA , LAN , Headphone/microphone combo jack , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Password Manager, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart, HP Driver Packs (free download)
Case Material
Brushed aluminium
Security
HP 3D DriveGuard, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Power adapter, HP Basic Carrying Case
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
2.19 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
CK8D HP 65W Smart AC Adapter In Stock £16.11
CK8D HP 90W Smart AC Adapter In Stock £19.56
CK8D HP 65W Smart AC Adapter In Stock £16.89
CK8D HP Keyed Cable Lock 10mm In Stock £26.40
CK8D HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £109.31
CK8D HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £138.07
Other bundles (1)
CK8D HP USB Travel Mouse In Stock £9.11
