HP Pro 400 G9 SFF Intel Core i5-12500 16GB 512G SSD Windows 11 Professional
Quicklinx: H9RTWS00 Mfr#: 6A7U7EA#ABU
  • Core i5
The HP Pro SFF 400 Desktop provides users in hybrid work environments with the commercial-grade configuration options and connectivity in a space-saving design. This PC is powered by the latest Intel processor and protected with always-on security you can trust.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • High performance, high portability
    Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • BIOS management over the network
    HP Sure Admin, a modern BIOS management tool, eliminates the need for a password or BIOS configuration utility in the OS by creating a digital signature that allows IT administrators to securely manage BIOS settings over a network.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen7 automatically recovers the BIOS from malware, rootkits, or corruption.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
HP Pro 400 G9 - SFF Core i5 12500 3 GHz - 16 GB - SSD 512 GB - UK
Personal computer - SFF
Intel Core i5 (12th Gen) 12500 / 3 GHz (up to 4.6 GHz, (6-core)
Processor Main Features
Hyper-Threading Technology, Intel Smart Cache, Intel Turbo Boost Max 3.0
Cache Memory
18 MB L3 Cache
Cache Per Processor
18 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
SSD 512 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 770 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
Keyboard
(50/60 Hz)
OS Provided
Windows 10 Pro (downgrade from Windows 11 Pro) + Windows 11 Pro Licence
Software Included
HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalogue (free download), HP Setup Integrated OOBE, HP Notifications, HP Connection Optimizer, HP Privacy Settings, HP Cloud Recovery, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, myHP, Touchpoint Customiser for Commercial, HP Desktop Support Utilities, HP Image Assistant Gen5 (free download), HP Easy Clean, HP Smart Support (free download), HP Manageability Integration Kit (free download), HP Patch Assistant (free download)
27 cm x 9.5 cm x 30.8 cm
4.2 kg
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
SFF
Sensors
HP Tamper Lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q670
Cache Memory
Installed Size
L3 Cache - 18 MB
Cache Per Processor
18 MB
RAM
Installed Size
Effective Memory Speed
3200 MHz
Rated Memory Speed
3200 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2 2280
1 x 512 GB
Interface Type
PCI Express
NVM Express (NVMe)
Storage Controller
1 x SATA
Channel Qty
3
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Mouse Name
HP 125
USB
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 4.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x M.2 Card - 2230 (PCIe x1 mode (for wireless module)) , 1 (total) / 0 (free) x M.2 Card - 2280 (PCIe x4 mode (for internal storage))
1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 3 x USB 3.2 Gen 2 (3 in front) , 1 x USB-C 3.2 Gen 2 (1 in front) , 1 x audio line-out/line-in , 1 x DisplayPort 1.4a , 1 x HDMI , 2 x USB 2.0 (wake functionality) , 3 x USB 3.2 Gen 1 , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
Security Slot Type
Kensington security slot
FCC Class B certified, ICES-003, CCC, FIPS 140-2 Level 2, RoHS, WEEE, KCC Class B, Common Criteria EAL4+, VCCI Class B, low halogen, CAN/CSA-C22.2 No. 62368-1, UL 62368-1, IEEE 1680.1-2018
Power supply
AC 90-264 V (50/60 Hz)
Power Provided
240 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
90% at 20% Load (115 VAC), 92% at 50% Load (115 VAC), 89% at 100% Load (115 VAC), 91% at 20% Load (230 VAC), 93% at 50% Load (230 VAC), 90% at 100% Load (230 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Software
Sustainability Information
TCO Certified
ENERGY STAR Certified
27 cm
9.5 cm
30.8 cm
4.2 kg
Shipping Width
39.4 cm
Shipping Depth
49.9 cm
Shipping Height
20.5 cm
Shipping Weight
7.25 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (4)
H9RT HP Care Pack Next Business Day Hardware Support - Extended serv In Stock £39.36
H9RT HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 5 years In Stock £84.57
H9RT HP Care Pack Active Care NBD Hardware Support - extended service agreement - 3 years - on-site In Stock £57.56
H9RT HP Care Pack Next Business Day Active Care Service with Defective Media Retention - 5 years on-site In Stock £139.36
Monitors (4)
H9RT HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £166.22
H9RT HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
H9RT HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £615.80
H9RT HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £167.33
Keyboards and Mice (2)
H9RT HP 128 Wired Mouse In Stock £8.49
H9RT HP 455 Programmable Keyboard - Wireless - UK In Stock £46.54
Other bundles (47)
H9RT HPE DisplayPort DVI-D Adapter In Stock £19.77
H9RT HPE DisplayPort to VGA Adapter In Stock £13.14
H9RT HPE USB to Serial Port Adapter In Stock £13.95
H9RT HP USB G2 Stereo Headset In Stock £20.27
H9RT HP Flex IO V2 Card - VGA port In Stock £12.28
H9RT Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
H9RT Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £216.07
H9RT Poly DA75 Sound Card In Stock £27.52
H9RT Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £103.25
H9RT Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
H9RT Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.34
H9RT Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
H9RT Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £103.25
H9RT Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £117.00
H9RT Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £117.00
H9RT Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £111.68
H9RT Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £108.17
H9RT Poly Voyager 4320 UC V4320 C USB-A WW In Stock £103.25
H9RT Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
H9RT Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £108.17
H9RT Poly Sync 10 SY10-M USB-A/C WW In Stock £53.41
H9RT Poly EncorePro 525 USB EP525 USB-A Headset In Stock £87.21
H9RT Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
H9RT Poly Sync 40 SY40-M WW In Stock £123.47
H9RT Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.67
H9RT Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.68
H9RT Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.27
H9RT Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.04
H9RT HyperX Cloud Stinger 2 Core Gaming Headset In Stock £37.49
H9RT HyperX SoloCast USB Microphone In Stock £50.55
H9RT HyperX Pulsefire Core Gaming Mouse In Stock £28.26
H9RT HyperX Pulsefire Mat Gaming Mouse Pad In Stock £12.63
H9RT Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
H9RT Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £59.09
H9RT Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £24.80
H9RT Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.67
H9RT Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
H9RT Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
H9RT Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
H9RT Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.17
H9RT Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £49.75
H9RT Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.40
H9RT Poly HP Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C In Stock £46.27
H9RT Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C In Stock £53.80
H9RT Poly Blackwire 3220 USB-C HS +USB-C/A Headset In Stock £26.96
H9RT Poly Blackwire 5220 USB-C HS +USB-C/A Headset In Stock £55.67
