The Blackwire 3200 Series provides a quality audio experience in a headset that's built for enterprise needs. With a sleek design and flexible microphone boom for a customizable fit, what's not to love?
Enhanced call quality
Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback. -
Connectivity options
Enhanced connectivity for your devices with a USB-C cord and tethered USB-A adapter. -
Wearing style
Hi-fi stereo wearing style for those who want a richer, more immersive experience. -
Lightweight design
A lightweight metal headband offers durability and a comfortable custom fit. -
Simple call management
Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status. -
Optimized for communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
 - Poly Blackwire 3220 - headset - USB-C
- Product Type
 - Headset - wired - USB-C
- Compatibility
 - Mac, Windows
- Recommended Use
 - Portable electronics, computer
 - Black
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Sensitivity 90 dB
- Impedance
 - 32 Ohm
- Signal-To-Noise Ratio
 - 118 dB
- Microphone
 - Boom
- Microphone Operation Mode
 - Omni-directional
- Microphone Noise Cancelling
- Controls
 - Mute, volume, answer/end, hold, redial
- Software Certification
 - Skype Certified, Cisco Jabber Certified, Avaya Certified, UC certified
- Product Type
- Series
 - Blackwire 3200 Series
- Compatibility
 - Mac, Windows
 - 15.5 cm
 - 3.2 cm
 - 17.8 cm
 - 92 g
 - Black
- Earpad Material
 - Foam
- Recommended Use
 - 270° rotatable microphone, boom mic length 130 mm
Audio Output
 - On-ear
 - Wired
- Sound Output Mode
 - Stereo
 - 118 dB
- Sensitivity
 - 90 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 28 mm
- In-Cord Volume Control
 - Dynamic EQ optimised, echo cancelation
Microphone
 - Boom
 - Omni-directional
- Sensitivity
 - -38 dBV/Pascal
- Frequency Response
 - 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
 - USB (24 pin USB-C)
- Included Accessories
 - USB-C to USB-A adapter, USB-C cable
- Cable Details
 - USB-C cable
- Supported Host Device OS
 - Windows 11, Windows 10, macOS
- Shipping Width
 - 18.5 cm
- Shipping Depth
 - 5.6 cm
- Shipping Height
 - 20.7 cm
- Shipping Weight
 - 242 g
                        Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.69 |
                        Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.85 |
                        Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.11 |
                        Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
