The HP Pro Mini 400 provides users with the commercial-grade performance, security,?and the flexible deployment capabilities?needed for small workspaces.?This?ultrasmall form factor PC?is?powered by an Intel ?processor?and?protected with always-on security you can trust.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
High performance, high portability
Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably. -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen7 automatically recovers the BIOS from malware, rootkits, or corruption. -
Work without interruption
Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen6 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks. -
Browse confidently
Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click. -
Erase your drive
HP Secure Erase removes the contents of a hard drive for repurposing or reassignment.
- HP Pro 400 G9 - mini Core i5 12500T 2 GHz - 16 GB - SSD 512 GB - UK
- Personal computer - mini
- Localisation
- Processor
- Intel Core i5 (12th Gen) 12500T / 2 GHz (up to 4.4 GHz, (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 18 MB L3 Cache
- Cache Per Processor
- 18 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 512 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 770 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.2, Wi-Fi 6E
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition (downgrade from Windows 11 Pro) + Windows 11 Pro Licence
- Software Included
- HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalogue (free download), HP Setup Integrated OOBE, HP Notifications, HP Connection Optimizer, HP Privacy Settings, HP Cloud Recovery, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, myHP, Touchpoint Customiser for Commercial, HP Desktop Support Utilities, HP Image Assistant Gen5 (free download), HP Easy Clean, HP Smart Support (free download), HP Manageability Integration Kit (free download), HP Patch Assistant (free download)
- 17.7 cm x 17.5 cm x 3.42 cm
- 1.42 kg
- Environmental Standards
- TCO Certified Desktops 9, ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Mini
- Sensors
- HP Tamper Lock
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q670
Cache Memory
- Installed Size
- L3 Cache - 18 MB
- 18 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 3200 MHz
- Rated Memory Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 512 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP 320K
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP 125
- Interface (Bus) Type
- PCI Express Mini Card (M.2)
- Wireless LAN Supported
- Wireless NIC
- Intel Wi-Fi 6 AX 211
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.2, IEEE 802.11ax (Wi-Fi 6E)
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.3az, IEEE 802.11r, IEEE 802.11v
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 (PCIe x1 mode (for wireless module)) , 1 (total) / 0 (free) x M.2 Card - 2280 (PCIe x4 mode (for internal storage))
- 1 x headphones/microphone (1 in front) (CTIA headset support) , 2 x USB 3.2 Gen 2 (2 in front) (one of them is charging) , 1 x USB-C 3.2 Gen 2x2 (1 in front) (charging) , 1 x USB 3.2 Gen 2 , 2 x DisplayPort 1.4a , 1 x HDMI , 2 x USB 3.2 Gen 1 (wake functionality) , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion sensor
- Security Slot Type
- Kensington security slot
- FCC Class B certified, ICES-003, CCC, FIPS 140-2 Level 2, RoHS, WEEE, KCC Class B, Common Criteria EAL4+, VCCI Class B, low halogen, CAN/CSA-C22.2 No. 62368-1, UL 62368-1, IEEE 1680.1-2018
- Power adapter
- Power Device Name
- HP Smart AC Adapter
- Voltage Required
- AC 90-264 V (50/60 Hz)
- Power Provided
- 90 Watt
- Efficiency
- 89% (230VAC), 88% (115VAC)
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
- Software
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.42 cm
- 1.42 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 13.2 cm
- Shipping Height
- 23.5 cm
- Shipping Weight
- 3.4 kg
- 5 °C
- 35 °C
- 5 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Business Day Hardware Support - Extended serv | In Stock | £35.99 |
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 5 years | In Stock | £77.67 |
HP Care Pack Active Care NBD Hardware Support - extended service agreement - 3 years - on-site | In Stock | £53.71 |
HP Care Pack Next Business Day Active Care Service with Defective Media Retention - 5 years on-site | In Stock | £136.51 |
Accessories (2)
HP B250 Mounting Kit for LCD Display/Thin Client | In Stock | £19.68 |
HP DM V4+ VESA Sleeve | In Stock | £25.22 |
Monitors (5)
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £161.91 |
HP OMEN 24" Full HD 165Hz Gaming Monitor | In Stock | £121.33 |
HP OMEN 27" Full HD 165Hz Gaming Monitor | In Stock | £145.60 |
HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £614.57 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £163.00 |
Keyboards and Mice (2)
HP 128 Wired Mouse | In Stock | £8.31 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £25.93 |
Other bundles (47)
HPE DisplayPort To VGA Adapter | In Stock | £12.06 |
HPE DisplayPort DVI-D Adapter | In Stock | £11.32 |
HPE USB to Serial Port Adapter | In Stock | £13.48 |
HP USB G2 Stereo Headset | In Stock | £19.85 |
HP Flex IO V2 Card - VGA port | In Stock | £12.26 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £214.79 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £208.54 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £108.13 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £103.93 |
Poly DA85-M Sound Card | In Stock | £44.59 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £67.63 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £43.49 |
Poly EncorePro HW510 Mono Headset (N/C) | In Stock | £72.29 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £110.24 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £98.40 |
Poly Voyager 4320 UC V4320 C USB-C CS WW | In Stock | £117.25 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £110.60 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £108.13 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £86.60 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £107.80 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £53.59 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £84.76 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly EncorePro 525 USB EP525-M USB-A Headset | In Stock | £42.59 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £108.13 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £29.77 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £29.77 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £66.81 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £43.83 |
HyperX Cloud Stinger 2 Core Gaming Headset | In Stock | £37.49 |
HyperX Pulsefire Core Gaming Mouse | In Stock | £27.07 |
HyperX Wrist Rest | In Stock | £20.11 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £61.36 |
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black | In Stock | £25.49 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £27.57 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £26.20 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £24.87 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £77.77 |
Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black | In Stock | £68.48 |
Poly EncorePro 530 - headset - Quick Disconnect | In Stock | £68.48 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £110.24 |
Poly EncorePro 540 - headset - Quick Disconnect | In Stock | £75.89 |
Poly EncorePro HW520D - headset - Quick Disconnect | In Stock | £105.92 |
Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.55 |
