HP Pro 290 G9 SFF Intel Core i5-12400 8GB 256GB SSD Windows 11 Professional
Quicklinx: HDTQWS00 Mfr#: 6B2S0EA
Processor Type: Core i5
Operating System: Windows 11 Pro
Hard Drive Capacity: 256GB
Storage Type: SSD
Processor Model: I5-12400
  • Core i5
£683.40 ex VAT
£820.08 inc VAT
The HP Pro SFF 290 helps optimize business resources. Equipped with a powerful Intel processor, essential tools, and security features for business, this affordably priced and easy to set up PC has a scalable and functional design that can grow with your business.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • High performance, high portability
    Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • Simple PC management
    Spend less time and get right to the updates you need with HP Support Assistant.
HP Pro 290 G9 - SFF Core i5 12400 2.5 GHz - 8 GB - SSD 256 GB
Personal computer - SFF
Intel Core i5 (12th Gen) 12400 / 2.5 GHz (up to 4.4 GHz, (6-core)
Processor Main Features
Intel Turbo Boost Technology 2, Hyper-Threading Technology, Intel Smart Cache
Cache Memory
18 MB L3 Cache
Cache Per Processor
18 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
Optical Storage
DVD-Writer
Graphics Controller
Intel UHD Graphics 730 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
(50/60 Hz)
OS Provided
Windows 11 Pro
Software Included
Dropbox (25 GB Cloud Storage) (free for 1 year), McAfee LiveSafe (1 year subscription), HP Audio Switch, HP Documentation, HP Setup Integrated OOBE, HP Support Assistant, HP System Event Utility, HP JumpStart, Xerox DocuShare (90 days trial)
9.5 cm x 30.3 cm x 27 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.5 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H670
Cache Memory
Installed Size
L3 Cache - 18 MB
Cache Per Processor
18 MB
RAM
Installed Size
Effective Memory Speed
2933 MHz
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
NVM Express (NVMe)
Storage Controller
1 x SATA
Channel Qty
3
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, VGA
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Keyboard, mouse
Keyboard
Keyboard Name
HP 125
USB
Mouse
Mouse Name
HP 125
USB
Remote Management Protocol
SNMP 2
ACPI support, Wake on LAN (WoL)
IEEE 802.3i, IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 4.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2242/2280
1 x headphones/microphone , 4 x USB 3.2 Gen 1 , 4 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC CFR47 Part 15 C, UL, CSA, LVD, ETS 300 328, ETS 300 826, IEC 950, RoHS, WEEE, CECP, SEPA, Taiwan Green Mark, Korea Eco-Label, Japan PC Green Label, ErP Lot 3 2013 Ready
Power supply
AC 90-264 V (50/60 Hz)
Power Provided
180 watt
Efficiency
90% (115VAC) / 92% (230VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 11 Pro
Software
Sustainability Information
ENERGY STAR Certified
9.5 cm
30.3 cm
27 cm
4.2 kg
Shipping Width
19.6 cm
Shipping Depth
49.9 cm
Shipping Height
34.2 cm
Shipping Weight
6 kg
5 °C
35 °C
5 - 90% (non-condensing)
Warranties (2)
HDTQ HP Care Pack Next Business Day Hardware Support - Extended serv In Stock £39.36
HDTQ HP Care Pack Active Care NBD Hardware Support - extended service agreement - 3 years - on-site In Stock £57.56
Monitors (7)
HDTQ HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £166.22
HDTQ HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
HDTQ HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £167.33
HDTQ HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £76.56
HDTQ HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £112.58
HDTQ HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £89.24
HDTQ HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £251.00
Other bundles (52)
HDTQ HP 325 Webcam In Stock £18.90
HDTQ Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
HDTQ Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £216.07
HDTQ Poly DA75 Sound Card In Stock £27.52
HDTQ Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £103.25
HDTQ Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
HDTQ Poly TRIO C60 EXPANSION MICROPHONES In Stock £147.98
HDTQ Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £65.27
HDTQ Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.34
HDTQ Poly EncorePro HW510 Mono Headset (N/C) In Stock £72.84
HDTQ Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
HDTQ Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £103.25
HDTQ Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £117.00
HDTQ Poly Savi 7320 Office S7320 Stereo Headset In Stock £242.98
HDTQ Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £117.00
HDTQ Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £111.68
HDTQ Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £108.17
HDTQ Poly Voyager 4320 UC V4320 C USB-A WW In Stock £103.25
HDTQ Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
HDTQ Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £108.17
HDTQ Poly EncorePro 525 USB EP525 USB-A Headset In Stock £87.21
HDTQ Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
HDTQ Poly Sync 40 SY40-M WW In Stock £123.47
HDTQ Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.67
HDTQ Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.68
HDTQ Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.27
HDTQ Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.04
HDTQ Poly Savi 8420 Office headset - on-ear - DECT / Bluetooth - wireless - active noise cancelling In Stock £164.89
HDTQ HyperX SoloCast USB Microphone In Stock £50.55
HDTQ HyperX Pulsefire Core Gaming Mouse In Stock £28.26
HDTQ HyperX Pulsefire Mat Gaming Mouse Pad In Stock £12.63
HDTQ HyperX Wrist Rest In Stock £20.11
HDTQ Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
HDTQ Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £59.09
HDTQ Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £24.80
HDTQ Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.67
HDTQ Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
HDTQ Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
HDTQ Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
HDTQ Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £68.08
HDTQ Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.17
HDTQ Poly EncorePro HW520D - headset - Quick Disconnect In Stock £105.92
HDTQ Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £49.75
HDTQ Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.40
HDTQ Poly Voyager Focus 2 - headset - USB-C via Bluetooth adapter In Stock £138.16
HDTQ Poly HP Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C In Stock £46.27
HDTQ Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C In Stock £53.80
HDTQ Poly Blackwire 3220 USB-C HS +USB-C/A Headset In Stock £26.96
HDTQ Poly Blackwire 5220 USB-C HS +USB-C/A Headset In Stock £55.67
HDTQ Poly Poly Voyager Focus 2 - Headset - On-Ear In Stock £133.27
Storage Type: SSD
Type: Personal computer
Case Style: Small form factor
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: £500 - £750
