The HyperX Pulsefire Core delivers the essentials for gamers looking for a solid, comfortable, wired RGB gaming mouse. The Pixart 3327 optical sensor gives players precise, smooth tracking with no hardware acceleration, and has native DPI settings up to 6200 DPI. The ergonomically-designed Pulsefire Core has textured side grips for a comfortable, no-slip grip, and its symmetrical shape is suitable for both palm and claw grip. It features high-quality switches with crisp tactile feedback rated for up to 20 million clicks. Customize lighting, DPI settings, and macros for 7 programmable buttons with HyperX NGENUITY software and set your mouse up just the way you want it. The large skates on Pulsefire Core help deliver accurate aiming by giving you a smooth, controlled glide as you move the mouse.
The solid Pixart 3327 sensor provides precise tracking without hardware acceleration and supports native DPI settings up to 6200. -
Seven programmable buttons
Pulsefire Core features seven programmable buttons with switches that provide crisp tactile feedback and are rated for 20 million clicks. -
Adjustable RGB lighting
Add an individual touch of RGB style to your setup.
 - HyperX Pulsefire Core - mouse - USB 2.0
 - Mouse
- Connectivity Technology
 - Wired - USB 2.0
 - 86.2 g
- Movement Detection Technology
 - Optical
- Buttons Qty
 - 7
- Movement Resolution
 - 6200 dpi
- Performance
 - Realtime sensitivity switching 800/1600/2400/3200 dpi, 20 million clicks, 220 ips tracking speed
- Gaming
 - RGB colour LED, Pixart PAW 3327 optical gaming sensor, 30G acceleration
- Cable Length
 - 1.8 m
 - 2-year warranty
- Designed For
 - Victus by HP Laptop 15, 16; HP 250 G9; Elite 800 G9; EliteDesk 800 G6; Laptop 14, 15, 15s, 17; Pavilion Plus Laptop 14; Pavilion x360 Laptop; Pro 290 G9
 - Mouse
- Gaming
 - 86.2 g
Input Device
 - Wired
- Interface
 - USB 2.0
 - Optical
- Buttons Qty
 - 7
 - 6200 dpi
- Performance
- Cable Length
 - 1.8 m
- Software Included
 - HyperX NGenuity Software
 - Limited warranty - 2 years
- Designed For
 - Victus by HP Laptop 15-fa0014ns, 16-d0026nb, 16-d1025nl, 16-e0021nl, 16-e0022nl, 16-e0054nl, 16-e0314nf, 16-e1900ng , HP 250 G9 Notebook , HP Elite 800 G9 , HP EliteDesk 800 G6 , HP Laptop 14-dq3210ca, 14-fq0200ca, 14-fq0210ca, 15-dw1025nk, 15s-eq1018ny, 15s-eq2049np, 15s-eq2050np, 15s-eq2083nl, 15s-eq2083ns, 15s-eq3005nl, 15s-eq3016nl, 15s-eq3020nl, 15s-eq3621nd, 15s-fq2119nl, 15s-fq4030nl, 17-cn1006ns, 17-cn2267st, 17-cn2775st, 17-cp1620nd , HP Pavilion Plus Laptop 14-eh0660nd , HP Pavilion x360 Laptop 15-er1003nm , HP Pro 290 G9
